Born to Lose, Live to Win
Rennshift manual or auto reverse lockout
I have one of these ordered. I saw a comment or two here about the reverse lockout
I’m wondering those of you that have had it a while, what have you preferred, the manual or the auto lockout? Doesn’t seem like much work to change them out to try both but I’m just curious
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 |
Ive had the manual switch on mine for 12 years or so...Never had a problem with it, easy enough to flip the switch. Great product!
1970 911E |
Besides having to manually switch it, any benefit to either?
And if using the manual lockout, what is the point of switching it off ever? I’m having trouble understanding the point of this
There are basically 2 reverse lockout options supplied with the rennshift. The auto, which works similar to the factory shifter, where the spring loaded tab will let you shift to reverse when coming from the neutral position, but will block reverse when coming fifth, forcing the downshift into 4th.
The manual option locks all entry to reverse. You have to manually reach down and move a lever to allow shifting into reverse. This manual movement of the reverse lockout is necessary every time you want to be able to shift into reverse. |
Banned but not out, yet..
An air cooled refrigerator. ‘Mein Teil’ |
I run a manual on mine. Only challenge I have with that is that the shift linkage in the back of the tunnel has to be set correctly. Be careful when you put the shifter in and make sure that the lockout actually works properly. Mine did not initially and I had to adjust the shifter linkage at the rear of the tunnel.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Good to know thanks
Ass-engine Nazi slot car -- PJ O'Rourke |
New-ish 911SC Targa Owner
The auto setting is a spring loaded finger that blocks the shifter from going straight down if you are in the 5-R plane. If you are in the N plane you can direct the shifter right and it pushes the finger and compresses the spring and you can go into 5th or R. Like Duc Hunter mentioned, double check that you have the shift coupler adjusted so that the lock actually works. I had to adjust mine too because it wasn't going over to the right far enough to be blocked by the finger. This shifter is such a great upgrade though. It transforms the car.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Aww, gotcha. But double clutching the 5-4 shift is like flossing your teeth. Nobody actually does it every day. LOL
