Transmission tools for 915 box
I am about to open up a 915 gear box for a rebuild. I got rid of all my 915 tools some time ago and would like to see if someone will want to get rid of their two syncro tools.
Also the large tool for the input shaft nut on the gear stack, I can either buy a crow foot tool, or weld a 1/2 shaft on a large socket.
Can anyone tell me what size the nut is? I do not remember.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-15-2019, 03:24 PM
(man/dude)
Jonny042's Avatar
41mm (I hope). That's the size of tool I got.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 05-15-2019, 03:29 PM
Under the radar
Trackrash's Avatar
Drimmel off the old dog teeth then heat and press on the new ones, no tool needed.
If you need the shift fork jig you can make your own.
or here is the .dxf https://drive.google.com/file/d/1anvc7IQeZjnWq6Kmcosa5HHxMKN6UTxH/view?usp=sharing
link Shift Fork Jig for 915s FREE
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-15-2019, 03:41 PM
TrackRash,
I did the dremmel thing once, I did not think it was elegant or effective use of tool. I would pay for the synchro tools and then resell them afterward. Or just keep them.
As for the alignment tool, I bought one for $20 back then, I know it is $100 now for a fooking piece of plastic. What a rip.
Is that drawing dimension in millimeters?
Old 05-15-2019, 04:56 PM
Will this work?
https://www.amazon.com/Williams-SCF52-Crowfoot-Wrench-8-Inch/dp/B005VNLNJS/ref=sr_1_7?keywords=1+5%2F8+inch+crowfoot&qid=1557965053&s=gateway&sr=8-7
Old 05-15-2019, 05:05 PM
Under the radar
Trackrash's Avatar
Originally Posted by yelcab1 View Post
TrackRash,
Yes, millimeters. The tolerance is more like + - .125mm. Autocad got carried away with the zeros....
I have used a bearing separator to remove the dog teeth, but that is when I want to re-use the dog teeth. https://www.harborfreight.com/large-bearing-separator-3979.html?_br_psugg_q=bearing+puller
Gordon
Old 05-15-2019, 05:24 PM
Under the radar
Trackrash's Avatar
BTW if you look at this thread there are a number of DIY tools. Gordo's 915 Transmission Rebuild
Gordon
Old 05-15-2019, 05:29 PM
I kept an old used clutch plate for this purpose. Somehow I knew I was going to need it. I would screw it to the garage wall and use it to hold the input shaft while I torque or remove the big nut. I guess the crow foot or homemade version will have to do.
Old 05-15-2019, 06:37 PM
(man/dude)
Jonny042's Avatar
I got this:
Sorry forgot link:
https://www.toolsource.com/trans-pump-alignment-c-1321_119_134/dodge-41mm-transmission-lock-nut-wrench-p-114525.html
WARNING!!! NO IDEA IF THIS WILL EVEN WORK, but it's my plan.
Old 05-16-2019, 05:45 AM
(man/dude)
Jonny042's Avatar
Originally Posted by Jonny042 View Post
I got this:
Sorry forgot link:
Worked like a charm! To loosen and tighten the nut. Best $10.95 I ever spent!
Old 05-18-2019, 05:28 PM
scottrx7tt's Avatar
I used the same exact tool. Worked great
Old 05-18-2019, 07:30 PM
