Deep cycle Optima
I have a deep cycle Optima
65 Amp hours 900 marine cranking amps W/ an AJ USA adapter plate bought it last year for the 911, but ended up changing out the alternator didn't realize it was deep cycle marine till recently Will that be an OK batt for an 88, 911? Thanks |
Re: Deep cycle Optima
Yeah, not really the optimum battery for this application. The way the plates are set up the deep cycle battery is used better to be really discharged before being recharged, the typical car battery is better suited to providing higher amperage over a short period and then being recharged. The plates in your deep cycle battery will probably shed rather quickly and you'll loose the high-amperage output you need to start.
Which is the ideal optima 88-911
but Jack Olsen has a better act going w/his battery.. give him or Tyson a PM for the mfg. and model |
yes, red tops are good for cars. blue is good for boats.
other than that I think they just make side post terminals or top mount. I'm often wrong about lots of things though. if you go back to where you bought your marine optima, it should become apparent. they are pretty cheap at costco. that's where I got my red top! |
I run a similar Optima in my BMW (which only gets driven a few times a month). It's been installed for over two years with absolutely no problems. As far as I can tell, it's relatively bulletproof.
Cheers, Chris |
RSR are you running a
Blue marine optima in your BMr ? |
Search the archives, lots of Optima info. The one Jack has I think is a Stinger, small and powerful. Got mine at www.sounddomain.com (yes it was targeted for the monster boom stereo guys).
Brad |
| All times are GMT -8. The time now is 07:06 PM. |
