Born to Lose, Live to Win
ramonesfreak's Avatar
Door speaker installation question
Im replacing my 5 and 1/4" speakers with 6.5" speakers
for some reason I thought I had 6.5" speakers in there
Im obviously going to need to enlarge the hole in my door panel and obviously I only get one shot at doing this right
is there any trick to getting the door panel hole lined up exactly with the hole in the sheet metal of the door?
I think the answer seems obvious and that this sounds like a stupid question but I was planning on cutting the door panels from the rear so I wont be able to eyeball it
maybe im overthinking it....how did you go about this
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 04-18-2019, 03:12 PM
oh and any thoughts on how to best cut the door panel?
Can I use a dremel with a specific bit? Im guessing a razor blade isnt going to do the job. Plastic feels pretty thick
1983 911sc
Old 04-18-2019, 03:13 PM
just had a thought
assuming the existing hole on the door panel is mostly centered with the hole in the metal door, i could probably use the included round mounting bracket that comes with the new speaker to mark the new circle that needs to be cut on the back of the door panel....making sure that the bracket is centered with the existing hole?
sorry, i failed geometry
1983 911sc
Old 04-18-2019, 03:21 PM
6.5 speaker upgrade
you can do it, just take your time
this is what i would do
1-trace the back of the door panel with the speaker template to the correct 6.5 size
2-peal back the leather around the speaker opening
3-with a pair of right turn tin snips cut the cardboard door panel not the leather
4- now that you have the new opening re-glue the leather around the speaker opening
so it looks factory again but with a 6.5 opening
5- put door panel back on door
6- with a sharpie trace your new opening
7- cut the new opening with tin snip or small air saw
8- test fit
9- wire it up
10- mount new speaker
11- repeat other side
12 have a few drinks and listen to your new tunes
1981 930 euro
SOLD 1980 911 targa euro
Old 04-18-2019, 03:26 PM
I bought some .5 or .75 inch spacers on amazon for less than $10 that let me use a 6.5” without cutting the door.
Old 04-18-2019, 03:42 PM
8- test fit
9- wire it up
Thanks. It occurred to me while looking at the doors and my old speakers that the answer would be alot clearer if I actually had the new speakers in hand....but I dont. Wont be here until Tuesday
I got shallow mount speakers (Infinity REF 6532ex) and it may be that they will take up much less space than I am imagining
I was curious to know where the sizing of a speaker actually comes from so I measured my old ones and the 51/4" is actually from mounting hole to mounting hole across diagonally, not the speaker cone itself...
1983 911sc
Old 04-18-2019, 03:54 PM
I assume your talking about something like this
https://www.amazon.com/Universal-Plastic-Adapter-Spacer-Speakers/dp/B00DJG80YA/ref=pd_sbs_200_2/134-1537715-8837119?_encoding=UTF8&pd_rd_i=B00DJG80YA&pd_rd_r=89e246f9-6234-11e9-b12e-253105b62179&pd_rd_w=oXiqG&pd_rd_wg=KoI4P&pf_rd_p=588939de-d3f8-42f1-a3d8-d556eae5797d&pf_rd_r=T4MNXB28T382YDM0NF0F&psc=1&refRID=T4MNXB28T382YDM0NF0F
And I assume the purpose of those is to keep less of the body of the speaker from actually going into the door?
1983 911sc
Old 04-18-2019, 03:56 PM
Yes, exactly! They blend nicely with my speakers (very conservative Rockford Fosgate) and don’t push them out so far as to hit the map pocket (assuming you don’t have RS style door panels).
Old 04-18-2019, 04:01 PM
scottrx7tt's Avatar
Kicker 6.5” speakers will fit without cutting anything
Old 04-18-2019, 04:03 PM
I'm good with tools.
AG81's Avatar
I built a set of these using plywood.....this was in 1988.....for a 79 911 (my brother). We wrapped them in door vinyl. It worked but the look always bothered me. Kind of an after thought look...... but it does work.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 04-18-2019, 06:39 PM
Buy a pair of speaker spacers from:
Porsche 911 Speaker Spacers (one pair) | Apex Paddles
See this thread for the hows and whys:
Door speaker spacers
Old 04-19-2019, 07:23 AM
Beat me to it!
Ass-engine Nazi slot car -- PJ O'Rourke
Old 04-19-2019, 08:30 AM
Cool. If I can’t get a good fit with the included bracket and fasteners, I’ll get a set of those
Old 04-19-2019, 08:36 AM
Vintage Owner
Jack Stands's Avatar
Those brackets also provide you with a great flat surface to mount the speakers.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 04-19-2019, 06:30 PM
Vintage Owner
Speaker. Panel
84 Targa (sold)
70 914-6 (sold)
2016 Cayenne
Old 04-19-2019, 06:32 PM
After getting the speakers today I see that I don’t need to cut bigger holes
I do however need those spacers so I just ordered a pair. Hopefully they being in Canada wont cause a huge shipping delay.
Anyway thanks for the suggestion
1983 911sc
Old 04-22-2019, 03:05 PM
Surface mount speakers or speaker covers with any significant depth will interfere with window wind handles. This doesn't apply if your vintage 911 has power windows.
Sherwood
Old 04-22-2019, 03:35 PM
Btw anyone that used those spacers, did you need longer screws than what your speakers came with?
1983 911sc
Old 04-22-2019, 04:01 PM
Speakers normally come with a variety of screws in different lengths. Mark the holes with a scribe or pen/pencil and drill pilot holes. Don't forget dynamat or similar on inside of door sheet metal. And always install new moisture barriers--they are cheap insurance.
Old 04-23-2019, 05:01 AM
Yea my speakers came with some longer screws. Just not sure they will go far enough into the spacers
Ok one last question for anyone using those spacers. I will need to remove the door panels several times this summer to address door dings etc
I’m worried that unscrewing the speakers from the spacers is going to strip the holes. Should I be concerned about this or is the material the spacers are made off able to handle having the screws in and out
Old 04-23-2019, 06:37 AM
