Front suspension mounting bracket
Hello,
I'm replacing the mounting bracket on the suspension. I'm removing the old one and plan to welded in the replacement bracket.
Since this is my first time doing this..not sure what to look out for..
Anyone attempted this before.. suggestion and comments are much appreciated.
Bao
Old 05-11-2019, 08:23 AM
I am interested to see how this goes. I have to do the same on my Rat Rod. I have not been able to find the part to buy, that would replace what's ruined on my car. I can find the entire pedal box panel etc, but didn't want to remove that whole thing to replace those 2 mounts.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 05-11-2019, 08:44 AM
try Quality Custom Porsche Panels | Restoration Design Inc. for parts
looks like you need a front pan.
Old 05-11-2019, 09:23 AM
Except those parts do not appear to be part of the suspension pan kit. They do appear to be available separately though.
Bearing Bracket for Pedal Área (steering rack mount)
911/912 Chassis: Restoration Design Inc.
Old 05-12-2019, 08:20 PM
I would rather be driving
jpnovak's Avatar
The process is relatively straightforward for the outer section. Don't forget to weld the top if the "pin" section of the capture nut. This goes all the way up into the front trunk where the front pan meets the bulkhead.
Make sure it is aligned properly (square and level) before burning metal into place.
Old 05-13-2019, 05:05 AM
jpnovak,
I think you have good knowledge about this.. what i'm not sure most is the end of the replacement bracket..where it seem to be cut off at the tip. Is this what you referring to as the "pin"?
if you look at my pic.. the existing bracket is still there. How do get this out? i noticed the inside of the trunk , directly above the bracket is a small bump..could this be the welded tip of the old bracket in place now? and if so , how do removed them.. just cut off the bump?
Old 05-13-2019, 05:37 PM
