Runnin on empty
Will a 74 CDI work in a 79?
I'm helping out a friend. His 79 3.0 CDI has crapped out and I have one from a 74 2.7. Can they be swapped?
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITBs, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff. https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html |
Under the radar
No. The SC CDI is a 6 pin unit, as opposed to the 3 pin from the '74. The SC unit is triggered from a magnetic unit in the distributor where as the '74 uses points. Not to mention the fact that the wiring harness and associated ignition wiring are totally different.
Runnin on empty
Thanks Trackrash! I’ll let my buddy know.
Armin
Trackrash is absolutely right. 3 pin vs 6 pin.
Sent from my iPhone using Tapatalk |
