Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Auto meter Tach Problems
I have an auto meter tach in my car and I am getting RF Interferance I think. It works great until I get to high RPMs then it starts to jump around. Any ideas how to solve this problem?
Thanks for the help
Old 03-20-2003, 07:53 AM
Tachometer
Please help!!!!!!!
Old 03-20-2003, 03:16 PM
Alter Ego Racing
ErVikingo's Avatar
Don't know directly what it could be but, are you using shielded spark plug wires?
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 03-20-2003, 03:36 PM
jake raby on the 914 pp board was looking for a more accurate tach at high rpms. do a search and see what he came up with.
are you running points or electronic conversion?
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 03-20-2003, 03:42 PM
I am running points with a crane Hi-6 unit and crane coil.
Old 03-21-2003, 07:49 AM
BIG BUMP
Please HELP
Old 03-21-2003, 03:41 PM
Vinatge, since you say you've got a Crane CD unit, and I've been researching MSD and Crane recently -- are you using a tach adapter? Did the tachstart misbehaving when you installed the Crane, or just all of a sudden?
Here is a quote from the Crane manual on troubleshooting noise:
1)Make sure a ground strap is installed between engine and chassis.
2) Make sure that [electronic stuff like gauges] are grounded direct to the chassis.
3) ...Make sure the HI-6 (Crane unit) is grounded direct to chassis. Keep the ground wire under 6 inches.
4)Replace spark plug wires with spiral core type wire. Put dielectric grease on the rotor tip and all igh voltage terminals. Use only resistor sparkplugs on the street.
Old 03-21-2003, 04:44 PM
Tach
Thanks, I will give all those a try.
Old 03-21-2003, 06:17 PM
Are most people taking the tach wire off the - side of the coil or are they running it off the tachoutput on the Crane or MSD Unit??
Old 03-23-2003, 08:41 PM
bump
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 03-24-2003, 01:44 PM
www.cranecams.com has the manual with several proper hookup diagrams. I'd start there.
Old 03-24-2003, 02:16 PM
