installing f.g. ducktail question
I will be installing a duck from MaShaw next week and I noticed there is no provision for the rubber bump stop that goes on the stock decklid.
Those of you who use a f.glass duck, How did you install the rubber bump stop/adjusters?
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
When I has a fiberglass tail, I had to drill a small hole and twist the rubber stops in. Personally, I think they're completely neccessary because if you don't have them the fiberglass tail will wear away while it rubs against the steel frame.
Good Luck! |
you might look at air filter housing mounts for older mb diesels. they have a stud on each side of a cylinder of rubber. you might be able to slice one down the middle. i have have never done it, but it sounds like a good solution.
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
RETIRED
Take the old tail, measure the hole....take a like size drill and make one....screw the rubbers in.......
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
You should drill holes in the same position as the factory lid and use the factory rubber bumpers. Once installed, you can twist them to adjust the height of the deck lid corner relative to the adjacent body surface.
Sherwood Lee http://members.rennlist.org/911pcars |
Dear god!!! I had heard that you 911 guys were a little twisted...but drilling holes in a ducks tail??? Someone should alert PETA!!!
Kevin, 1969 912 1992 Firebird 1985 Eldorado(SS roof) 1992 Ranger PU 1976 Cutlass(tha beast) various others in the country for parts |
drill holes. ask questions later.
I was considering drilling a hole in the tail and filing the grooves in the bumper stop a bit bigger. F.G. is thicker than the sheetmetal. I can drill a hole in the tail no problem it seems the sheet metal has a chamfer on it to help the bump stop stay in place. I think I am going to drill a small hole and tread in a rubber foot w/ a small screw attached and file it to the right size. If it doensn't work, I'll drill a bigger hole and put on the factory bump stop.
you should check out the air filter mounting bushings at you local mb dealer.
Quack! |
"I was considering drilling a hole in the tail and filing the grooves in the bumper stop a bit bigger. F.G. is thicker than the sheetmetal. I can drill a hole in the tail no problem it seems the sheet metal has a chamfer on it to help the bump stop stay in place. I think I am going to drill a small hole and tread in a rubber foot w/ a small screw attached and file it to the right size. If it doensn't work, I'll drill a bigger hole and put on the factory bump stop."
All this is not necessary unless the FG is too thick (if it is, remove some FG w/a sander). Chamfer to keep in place? The rubber stop threads into the hole. Friction between rubber and FG will keep it in place. Fussing here is not necessary. Sherwood |
