Thanks JT, I have the same HF dolly :)
I also need to replace this starter stud on my 73S but mine measures 123mm and 104mm sticks out after inserting. This one above measures 140mm and I wonder if I cam mount my starter. Even if I use a regular nut rather than the barrel nut there may not be enough thread.
Transmission is out for repair so I can't measure |
| All times are GMT -8. The time now is 09:31 PM. |
