khamul02's Avatar
Oil Amount for SC AC
Backstory.... I have replaced all hoses.. flushed all components, replaced dyer and expansion valve.. added the specified amount of oil to the compressor (after draining it).
I read somewhere that you should add some additional oil to the system given how much hose there is, if so how much, 2 or 3 ounces?
Thanks,
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 06-04-2019, 06:28 AM
Hopefully Charlie Griffith will reply. Yes, you will need to add some oil.
I don't doubt the answer has been posted many times before in previous threads.
You will need to add some to the evaporator, and all the condensers, and the compressor if you flushed that.
Old 06-04-2019, 06:58 AM
