jmz jmz is online now
jmz's Avatar
installing f.g. ducktail question
I will be installing a duck from MaShaw next week and I noticed there is no provision for the rubber bump stop that goes on the stock decklid.
Those of you who use a f.glass duck, How did you install the rubber bump stop/adjusters?
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 03-20-2003, 11:13 AM
When I has a fiberglass tail, I had to drill a small hole and twist the rubber stops in. Personally, I think they're completely neccessary because if you don't have them the fiberglass tail will wear away while it rubs against the steel frame.
Good Luck!
Old 03-20-2003, 11:19 AM
you might look at air filter housing mounts for older mb diesels. they have a stud on each side of a cylinder of rubber. you might be able to slice one down the middle. i have have never done it, but it sounds like a good solution.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 03-20-2003, 11:40 AM
RETIRED
Joe Bob's Avatar
Take the old tail, measure the hole....take a like size drill and make one....screw the rubbers in.......
2012 ML350 3.0 Turbo Diesel
Old 03-20-2003, 12:57 PM
You should drill holes in the same position as the factory lid and use the factory rubber bumpers. Once installed, you can twist them to adjust the height of the deck lid corner relative to the adjacent body surface.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 03-20-2003, 12:59 PM
Dear god!!! I had heard that you 911 guys were a little twisted...but drilling holes in a ducks tail??? Someone should alert PETA!!!
Kevin,
1969 912
1992 Firebird
1985 Eldorado(SS roof)
1992 Ranger PU
1976 Cutlass(tha beast)
various others in the country for parts
Old 03-20-2003, 01:13 PM
drill holes. ask questions later.
Old 03-20-2003, 01:17 PM
jmz's Avatar
I was considering drilling a hole in the tail and filing the grooves in the bumper stop a bit bigger. F.G. is thicker than the sheetmetal. I can drill a hole in the tail no problem it seems the sheet metal has a chamfer on it to help the bump stop stay in place. I think I am going to drill a small hole and tread in a rubber foot w/ a small screw attached and file it to the right size. If it doensn't work, I'll drill a bigger hole and put on the factory bump stop.
Old 03-20-2003, 01:18 PM
you should check out the air filter mounting bushings at you local mb dealer.
Old 03-20-2003, 01:35 PM
Wavey's Avatar
You might try drilling the same size hole, then use a counter-sink bit (which is a short little bit, about 1/2" diameter with a 45-degree point), which would provide the chamfer AND leave the f/g thinner at that point where the rubber screws in.
Quack!
Old 03-20-2003, 02:00 PM
"I was considering drilling a hole in the tail and filing the grooves in the bumper stop a bit bigger. F.G. is thicker than the sheetmetal. I can drill a hole in the tail no problem it seems the sheet metal has a chamfer on it to help the bump stop stay in place. I think I am going to drill a small hole and tread in a rubber foot w/ a small screw attached and file it to the right size. If it doensn't work, I'll drill a bigger hole and put on the factory bump stop."
All this is not necessary unless the FG is too thick (if it is, remove some FG w/a sander). Chamfer to keep in place? The rubber stop threads into the hole. Friction between rubber and FG will keep it in place. Fussing here is not necessary.
Sherwood
Old 03-20-2003, 02:05 PM
Wavey's Avatar
Sherwood [/B]
Hey - it's a P-Car - fussing is REQUIRED! :>
Old 03-20-2003, 02:11 PM
