jtkkz's Avatar
Question MSD and Tach need expert advise?
1973.5 Porsche 911T
I have installed a MSD 6AL, msd tach adapter and a MSD blaster coil.
The tach stop working, aside from sending out my tach to Palo Speedo or North Hollywood Speedo, Is there other ways of making it work?
I need expert advise from someone who has installed this product before and made it work by using this MSD products.
I have wired this a few different ways with no luck.
Let me know
Thank You for your replys
Old 03-20-2003, 05:29 PM
Navin Johnson
TimT's Avatar
If the tach needle doesnt move at all, check the wiring. If the needle moves erratically, you probably need a tach adapter. Early tachs work on a different signal than later tachs.
'69 911 GT-5
'75 914 GT-3
and others
Old 03-20-2003, 05:45 PM
jtkkz's Avatar
When I first installed it the tach needle worked erractically, then it stop and then it would occasionally work between 1000 - 2000 rpm only.
Well now it completely stop working.
I do have a tach adapter hooked up to it already.
Please feel free to give any advise you know off.
Early Porsche Reproduction Products:
http://sycipworks.tripod.com/
Old 03-20-2003, 06:03 PM
jtkkz's Avatar
Any mechanics out there that have done this type of install before and made the the tach work?
If you are willing to help me it would be greatly appreciated.
Thank You
Old 03-20-2003, 06:05 PM
canna change law physics
red-beard's Avatar
Sorry, what you describe is similar to what happened with my 914/6. I tried everything. Finally ended up sending it off to NorthHollywood speedo. $130 later it works perfectly. You could also accomplish this by finding and using a later model tach. Not sure which year is where the internal change occured.
James
James
Red-beard for President, 2020
Old 03-20-2003, 06:13 PM
jtkkz's Avatar
Thank You
I think I am leaning towards sending out my tach to North Hollywood as well.
Are they a good company to deal with. Are they true to there word of one week turn around.
Is the tach very simple to remove.
Old 03-20-2003, 06:17 PM
jmz jmz is online now
jmz's Avatar
my 3.0 in my 74 911 w/ original tach works fine w/ the msd and no tach adapter.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 03-20-2003, 06:20 PM
red-beard's Avatar
The tach was from an original 1970 Factory 6. Now it works without the tach adapter.
James
James
Old 03-20-2003, 06:28 PM
