Rear seat reclines on its own
I have been searching around this morning and cannot find an answer to this. My drivers seat (and passenger I think) seem to recline as I drive. They are manual seats, and it seams like the action o the seat back bouncing up/down a little as you drive over bumps causes the seat to recline. This means I have to reach back and wind it back up every so often.
I would think there is some kind of washer or spring that is suppose to hold some tension not he seat back mechanism so it does not recline as I drive. Any one have a clue what part I need to fix/replace to prevent this from happening?
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 04-15-2019, 05:10 AM
Well this is frustrating. No one know why the stock manual seats might recline on their own as you drive and hit bumps, or what might be adjusted/repaired to prevent this? Seems like it would be a common problem as these seats get older. Hmmm
Old 04-30-2019, 07:19 PM
schoward's Avatar
My drivers seat recently seems to do same thing
Anyone have any tips on this ? My drivers seat seems to do the same. Never an issue for 14 years but upholstery shop recently had seats apart to redo bolsters on seat backs.... any kind of adjustment for tension or locking? All works ok but seems like I have to reset the seat recline back up every so often
Scott
1981 911SC Targa - Platinum Metallic
Old 05-25-2019, 10:53 AM
Designer King
Paulporsche's Avatar
There is a somewhat circular tensioning spring in behind the adjustment knob. If you go to the Porsche website and check out the parts diagrams for your year you can see an exploded illustration of a seat. It is part number 91152157100.
Beyond that, I'm afraid I don't know. Maybe you can remove the knob, expose the spring, and tighten it somehow, maybe by bending it.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-25-2019, 11:46 AM
