This is what happens when you have ADD
Well in the process of wiring in new distributor I rerouted the wires with a common theme.
http://forums.pelicanparts.com/uploa...1558899726.jpg http://forums.pelicanparts.com/uploa...1558899775.jpg |
ADD or OCD?
Unfortunately both I’m doing 5 different things at once and all have to be perfect
Ocd
The man is a mess, however you label it!
I see no reason to not route the right side spark plug wires over the fan strap.....and one reason to not do what was done here. Those wires will be an issue when the engine is removed from the car.
I agree, my OCD would make me go in and route the wires correctly the way tjenPorsche engineers designed it and have them at the correct length. Seems like a fix for a non existing problem and does not look right to me, but may be more a question of taste...
Did not want to route them over the fan strap or the way Porsche did it . How will it be an issue when removing the motor? They are actually the correct length to route over the fan but why cover the fan strap.
This was totally a personal choice/taste issue.....I don't see any issue with removing the engine.....I don't do my mod's based on ease of engine removal......
I would need pics of the rest of the car to determine if your routing of the plug wires was correct or not.
OP - nice work. Original. |
I like the look,,,very clean
I am OCD as well :-) |
Having those wires flopping around so they can snag on something is the problem. You really want them in a place they are out of the way. Also, it looks like those wires are not fully captured by whatever retainers you are using. If one comes loose it will be sucked in toward the fan belt which will saw through the wire in no time. But hey, it is your car so you should do what you think is best! |
Winders please enlighten me as to how any of the wires will come loose as they are all held down by wire separators that are all mounted to sheet metal. Nothing can move. Also nothing against doing it “Porsche’s” way. Just wanted something different to set my car apart.
Hey Warner you’re giving me anxiety looking at those wires,but hey at least they’re for a twin plug:D |
Rest off the engine bay.
http://forums.pelicanparts.com/uploa...1559163458.jpg And definitely not a stock front boot. http://forums.pelicanparts.com/uploa...1559163660.jpg |
http://forums.pelicanparts.com/uploa...1481218761.jpg |
I have CDO. It’s sort of like OCD but the letters have to be in alphabetical order.
| All times are GMT -8. The time now is 08:37 AM. |
