-   -   Any Idea What Part is This? (http://forums.pelicanparts.com/porsche-911-technical-forum/1030599-any-idea-what-part.html)
speeds5 05-26-2019 12:46 PM
Found this little part stuck to the magnet of the oil drain plug when I was changing the oil. Any idea what it is and where it dropped from? Car been running fine.
http://forums.pelicanparts.com/uploa...1558899919.jpg
rswannabe 05-26-2019 01:05 PM
Hate to say it, but it looks to be one of your timing chain master link retaining clips. You need to pull your chain covers and inspect ASAP. Don't run the motor or you risk the chain separating and catastrophic head damage.
https://www.eeuroparts.com/Parts/196566/Timing-Chain-Master-Link-14970/
dan88911 05-26-2019 01:09 PM
I believe it is call an E-clip.
john walker's workshop 05-26-2019 01:25 PM
Jesus clip out here in the west. I second the master link clip.
speeds5 05-26-2019 01:31 PM
Man that’s not good. Gotta open this thing up now and got a race on Thursday. Thanks for the help guys
Amstaff 05-26-2019 01:45 PM
Depending on which direction they put the link in you may be able to replace it by just pulling the timing chain cover.
dannobee 05-26-2019 01:59 PM
Look at it this way, you dodged a bullet. Even if you can't fix it in time to make the race, you saved yourself a ton of money.
rswannabe 05-26-2019 04:26 PM
My dad calls these "oh s**t!" clips, because when you find one (or lose it) you say "oh s**t!"
speeds5 05-26-2019 04:38 PM
Did a inny minny miney mo and started with the left side. Took the left cover off, both clips were in place. No luck. Took off the right cover and here’s the missing clip. I don’t want to use the old clip so overnighted one along with the gaskets, hopefully it gets here on time for the race.
Two thumbs up for the magnet drain plugs. If that hadn’t caught it, would have never known until potentially catastrophic failure. Frequent oil changes help too. Not
Much time between changes for things to go too wronghttp://forums.pelicanparts.com/uploa...1558913778.jpg
rswannabe 05-26-2019 05:01 PM
Congrats on catching it before it caused damage!
