Any Idea What Part is This?
Found this little part stuck to the magnet of the oil drain plug when I was changing the oil. Any idea what it is and where it dropped from? Car been running fine.
2007 GT3 RS Orange/Black 1986 911 Carrera White (dedicated race car #23) |
Hate to say it, but it looks to be one of your timing chain master link retaining clips. You need to pull your chain covers and inspect ASAP. Don't run the motor or you risk the chain separating and catastrophic head damage.
https://www.eeuroparts.com/Parts/196566/Timing-Chain-Master-Link-14970/
Brooke 1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black) 1952 MG TD with F20C |
I believe it is call an E-clip.
Jesus clip out here in the west. I second the master link clip.
Man that’s not good. Gotta open this thing up now and got a race on Thursday. Thanks for the help guys
Depending on which direction they put the link in you may be able to replace it by just pulling the timing chain cover.
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 |
Look at it this way, you dodged a bullet. Even if you can't fix it in time to make the race, you saved yourself a ton of money.
My dad calls these "oh s**t!" clips, because when you find one (or lose it) you say "oh s**t!"
Did a inny minny miney mo and started with the left side. Took the left cover off, both clips were in place. No luck. Took off the right cover and here’s the missing clip. I don’t want to use the old clip so overnighted one along with the gaskets, hopefully it gets here on time for the race.
Two thumbs up for the magnet drain plugs. If that hadn’t caught it, would have never known until potentially catastrophic failure. Frequent oil changes help too. Not Much time between changes for things to go too wrong
Congrats on catching it before it caused damage!
