3.6 transplant exhaust... A California solution...
This is what we've come up with. It's an elegant bit of welding using the stock 993 header. Two separate equal length pipes incorporate a small race cat, glasspack muffler, then post cat. The right bank hosts the O2 sensor.
It is louder that stock. About "flowmaster loud" but it has that nice flax 6 pitch.
Moses, that looks really good, but I thought CA engine swaps were required to keep all the "original emissions equipment" of the later engine...meaning the stock cat. Are you betting that the techs won't know the difference, or is there an allowance in the rules to do this kind of thing?
Colin
993 |
Mark,
that looks damn nice. Are you going to plump heat at some point in the future? My setup (former Paul's) will be similar. It won't use cats though. My car is a 74 and I don't have to worry about smog any longer. BTW: If someone is planning on something like that I have a set of 993 heat exchangers just like the ones pictured including flip-stud adapters (for 964 engine) for sale. I hope your 993 will get unleashed this week. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
is
Believe it or not, up close it looks like a stock setup. The bends are elegant and the pipes exiting under the muffler are very symmetrical.
Strangely, California regulatons allow after market cats if the original is not serviceable. Yes, I will be adding heat. I'm going to use one of Thoms RS bypass tubes. But right now I just want to DRIVE!
Montana 911
Great Job...soon I will post pics of my Euro spec exhaust (or Harald spec), I am told by Harald that it will be nice a low tones at lower rpms...then get a little loud at +3k rpm and LOUD at +5k rpm.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
looks much cleaner then the sone of the previous solutions...
congrats |
Nice job Moses--hows it running now?
1980 911SC Targa 3.6L |
Looks like you found a great solution. Hope the motor gets running on all 12 plugs soon. I can't wait for the ***** eating grin post that is soon to come.
That looks OEM. Very well done.
Chuck Moreland - elephantracing.com - vonnen.com |
Looks like a good solution!
You've got the sources for th SCAT tubing for the heat?
Aircraft Spruce follow the links > airframe parts > ducting. SCAT silicone tube is what you want.
Senior Member
Moses,
ACS (aircraft spruce) has loads of tubing but they are also expensive. Let me know if you want some more sources for SCAT/SCEET and other aircraft tubing suppliers. Ingo, What are you asking for the exhaust? Right now I am getting by with no Cat on my 3.2 but but am dreading what would happen if I get a spot check. When I get Bill's 3.6 installed have been thinking of working up a exhaust with a cat in it just in case. Thx, Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Metal Guru
Moses, nice job but why do you have the tailpipes pointing at the ground like an econobox sedan?
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Hey Joe,
What other kind of tubing suppliers do you know. I am always looking for tubing suppliers
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Actually, I haven't decided on which 4" chrome Folgers tips to weld on.
Moses--Magneflow makes a 4" round tip that is only about 5" long which was exactly what I needed in the limited space I had. Stainless steel--around $35 each. Here's a pic.
Senior Member
Dean,
Fresno Air Parts 559 237 4863 Aircraft Supply 800 569 9397 (PA) Chief Aircrafts Supply www.chiefaircraft.com (OR) These are all good supply houses. If you are looking for aircraft quality hardware, go to any small airport and stop in the pilot shop. Ask for a "trade a plane" newspaper and there are hundreds of adverts there every week for suppliers. Joe
