RDM RDM is offline
Coram Deo
RDM's Avatar
911SC no spark
It died in my garage when I was moving it out of the way. It ran, it died, it would not restart. Checking with a timing light and with a spark detector revealed no spark. Fuel comes on when the air metering plate is lifted.
All specs are lifted from previous Pelican threads.
Black Bosch coil tests 1.2 ohms primary (should be 0.6-0.9, out of spec), 680 ohms secondary (650-790, in spec). Replaced with second black Bosch coil in spec, no change.
Resistance between poles 7 and 31d on the 6-pin CDI connector ~600 ohms, in spec. I think this is the green wire, yes?
AC voltage between poles 7 and 31d climbs to ~1V on cranking with fuel pump relay disconnected. Out of spec (should be ~3 volts).
CDI unit is the Classic Retrofit CDI+. The tach needle completes its sweep when key is turned on, so it has power. Substituting Bosch CDI did not solve the problem.
Ideas? What next?
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 08-06-2025, 05:16 PM
Lash
check for spark at the coil's high-tension lead and then at the spark plugs. Remove one of the plug wires and grab a known good spark plug and hold to a good ground. If no spark, inspect the distributor rotor and cap for wear or damage. Check for proper power and ground to the CDI unit and coil.
Lash
1963 356 T-6 Normal Coupe
1972 911 T Coupe ..... Sold
1972 911 S Targa ...... Sold
1980 911 SC Coupe Weissach
Old 08-06-2025, 07:31 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Cap and rotor new 200 miles ago, and still look new.
No spark at the coil, no spark at the spark plug.
11.9V between pins 15 and 31/1 (system power for CDI unit)
67Ω between 31/1 and engine mount bolt head (system ground).
Seems like a CDI problem.
Dru
Old 08-11-2025, 05:18 PM
Warren Hall Student
Bobboloo's Avatar
I suspect the green wire from the dizzy to the CDI. They get baked and the insulation cracks.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 08-11-2025, 08:24 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Except the wire's resistance checks in spec and it produces its desired 1V AC on cranking. It connects to terminals 7 and 31d on the CDI connector. Could it still be the problem if it meets those criteria?
Dru
Old 08-11-2025, 09:26 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I can only speed for a Bosch CDI box. I assume it makes its distinct whine when powered.
With a spark plug hooked up directly to the coil output and grounded it needs to produce a spark assuming your trigger signal is present during cranking. If not the CDI box needs repair or the coil is no good.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 08-13-2025, 06:21 AM
CDI Loaner…….
Dru,
Are you now back in USA? Last time we communicated you were stationed in Germany. If you need a good CDI to use for your troubleshooting, I could lend you one and send it back to me later. Or send your CDI to either Ingo or Bob A. for evaluation.
Tony
Old 08-13-2025, 07:02 AM
Originally Posted by boyt911sc View Post
Dru,
Tony
There's another source that's been repairing CDIs for Porsche dealers/independents, and Porsche owners, for 35+ years with a 5 year warranty, systemsc.com.
Some still remember they were the Pelican Parts only CDI repair source. They indicate over 10% of their present Porsche electronics repair comes from Pelican members,
not only CDIs.
Furthermore, they are on the Porsche "Preferred Vendor" list.
Dave
Old 08-13-2025, 08:48 AM
ischmitz's Avatar
Originally Posted by mysocal911 View Post
There's another source that's been repairing CDIs for Porsche dealers/independents, and Porsche owners, for 35+ years with a 5 year warranty Some still remember they were the Pelican Parts only CDI repair source.
yup - some might even remember when Wayne had to ban you because people threatened to boycott Pelican Parts with you insulting others as LorenFB
Old 08-13-2025, 09:11 AM
Dave (Loren),
I intentionally did not include Systemsc.com because I knew you would jump in and recommend your company.
Tony
Old 08-13-2025, 02:09 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Dru,
Tony
Tony,
We moved back to the US about 2 years ago and are now in Kentucky.
I'd love to try a loaner CDI box, as everything else seems to check out OK. I will send you a PM.
And I have a backup CDI box that I will get evaluated as well.
Thanks!
Dru
Old 08-13-2025, 06:26 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Ingo,
The CDI+ does a nifty tach sweep to let you know it has power. No loud whine, though. I kind of miss it, but enjoy the reliability.
Regarding the trigger signal, Jonny at Classic Retrofit has been going through this with me and he pointed out the CDI+ has a green LED beneath the top mounting bolt that flashes with signal. I have signal.
Dru
Old 08-15-2025, 09:28 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
As mentioned above, Jonny at Classic Retrofit responded to my customer support request and has been troubleshooting with me. Turns out that the CDI+ has a signal LED at the top of the box (it's inside, but you can see the light shining through a small hole). that confirms signal from the distributor. Given that I had signal, he said it must be "on the output side," that is the coil, the distributor, or the plugs.
So, commence coil exchange.
The two black Bosch coils measure in spec, the black 123ignition coil is not in Porsche spec but is close and came out of the car I drove today (known to work), and the silver and blue coils have out-of-spec secondary resistances. Not sure they would work or not, but it turns out not to matter.
Say, what's this behind the coil?
This just might be the problem.
The shielding is hard as a rock. Not sure how severed the copper is, but the wire insulation is still pliable. Once I cool down, I'll go back out and see what I can do with this.
In all the troubleshooting guides I've read, I don't remember ever seeing "Check that the coil is getting power."
Dru
Old 08-15-2025, 09:41 AM
ischmitz's Avatar
Looks like you found your issue, good job
Old 08-15-2025, 09:44 AM
The coil doesn't get "power", it gets a spark pulse - less than a millisecond.
If the two leads shorted at the bad insulation, the CDI may have been damaged.
Dave
Old 08-15-2025, 11:37 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
Well that's not good news.
Perhaps a prompt to check continuity of the coil leads with the 6 pin connector.
Dru
Old 08-15-2025, 02:32 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
not only CDIs.
Dave,
Given how you treat people here, unless I had no other choice I wouldn't consider doing business with you.
Dru
Old 08-15-2025, 02:35 PM
Dave,
I guess you don't follow my many posts, where posts are just to provide PP Forum help on many Porsche topics. I don't see much from you!
I help everyone, even ones like you! I'm sure systemsc.com, given their CDI repair volume, really couldn't care less for an insignificant $250 CDI repair order.
Furthermore, they don't repair the Classic Retrofit CDI+.
Consider searching the Forum about how CDIs function, it'll be helpful in your present troubleshooting.
Dave
Old 08-15-2025, 02:50 PM
Interesting that you quote my help (post 16), but make negative comments subsequently;
Dave
Old 08-15-2025, 03:17 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Thank you, Dave.
Dru
Old 08-15-2025, 04:52 PM
