Taxidodger
High torque starter recommendation
Any recommendations for a high torques starter (for higher compression 3.4 engine)
Considering Tilton 3HP, WOSP, SSP, PMB, IMI - or wherever your experience has led you.
thanks
Old 11-08-2025, 02:18 PM
Location: behind the redwood curtain, (humboldt county) california
Wosp
I've got their high torque starter on my 2.8, with 10.5 JE pistons, spins right up :-)
Only have about 200 miles on the raging - restomod.
No porblems, but have no idea of the potential long term durability. Probably be just fine.
c
Old 11-08-2025, 03:18 PM
I have had the IMI for a few years on an 85 with stock drivetrain. I installed it. It has been working just fine!
Old 11-08-2025, 06:03 PM
Brise Co-axial starter. Tiny, doesn’t weigh much, used by Singer
https://brise.co.uk/product/porsche-911-7635091axgac/?v=7885444af42e
Old 11-09-2025, 12:31 AM
It's a 914 ...
stownsen914's Avatar
The Brise unit sure looks nice, the fact that it's used by Singer is a good endorsement. Under 6 lbs is impressively light. A bit expensive.
Old 11-09-2025, 05:42 AM
Taxidodger
Thanks everyone - appreciate the speedy replies
Old 11-09-2025, 05:50 AM
Burnin' Rubber
Koizumi's Avatar
Wish I’d seen that offering before i installed my big ol’ heavy Bosch unit. I shoulda went hi-torque and small size. Oh well. Next time
Old 11-09-2025, 01:02 PM
917_Langheck's Avatar
An IMI 101N is 25% the spend of that Brise. But if you have the dough for that show....
Old 11-09-2025, 10:34 PM
Call 911
dkirk's Avatar
I've equipped my '88 911 with the IMI starter several years ago. Being a reduction-drive starter, it cranks the engine a bit slower than the OEM Bosch. But the engine always starts after about a 2-second crank. I'm pleased in all respects.
Dave Kirk
My Porsche restoreth my soul.
Old 11-10-2025, 12:49 PM
Still here
pmax's Avatar
But then the startup will sound like a Honda.
I will miss that nice Bosch rumble.
Old 11-11-2025, 10:14 AM
Burnin' Rubber
Koizumi's Avatar
Haha very true! Cheers
Old 11-11-2025, 10:38 AM
And this is before you figure in whatever tariffs are arbitrarily applied to the shipment.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 11-11-2025, 11:04 AM
It does take a while to get used to the different sound. My much more important criteria was to hear the damn starter doing something!
I went through two different Bosch starters, one new out of the box. When I did a long road trip of 10 to 12 hours in the summer heat, the Bosch starter would get a heat soak, and just lock up and be non functional. I had both checked at starter rebuild shops. Both said it is now fixed. They were wrong. They worked just fine is around town driving.
It was the worst if I arrived at the hotel after a long drive, stood in line, and registered, got my room key, and a map to my room. 20 minuets time. Them I had to push start the 911.
I have had my high torque started for 60,000 miles and many more long summer time trips, and it always spins the engine as designed. It is a wonderful sound that sure beats silence when twisting the key.
Old 11-11-2025, 01:58 PM
Call 911
dkirk's Avatar
Reduction drive starter sound reminds me of a '70's vintage Plymouth Belvedere with a 225 cu in slant 6. But you get used to it. Reliability is what counts.
Dave Kirk
Old 11-11-2025, 03:50 PM
Still here
pmax's Avatar
Haha, of course it's true.
Cheers !
... It is a wonderful sound that sure beats silence when twisting the key.
Originally Posted by dkirk View Post
... Reliability is what counts.
And yes, my beloved air cooleds will never be as reliable as my Honda.
Cheers to you both too !!
Old 11-11-2025, 04:58 PM
