vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Starting Issues??
Just revived the car after a long Winter and and many suspension upgrades. After not runiing for several months the car started right up. Now after running for a couple weeks it is starting very rough, but after it is warm there is no problem. Changed the plugs and filled the tank up with new gas and the problem persists.
I used to be able to just turn the key without giving it any gas, but now I have to slightly pump and she is still rough for a few minutes. Where should I start? Injector cleaner? Wires (they are the original ones)? Just concerned it will get progressively worse?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 03-21-2003, 04:04 AM
Send a message via ICQ to old_skul
Sounds like bad gas. You can either drain the tank, or just run what you have left and fill it up with a fresh tank.
You may want to change out your fuel filter regardless.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 03-21-2003, 12:31 PM
GFCC
Jeff's Avatar
I would run some injector cleaner thru it. The old gas may have left deposits/ film on your injectors.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 03-21-2003, 01:11 PM
vesnyder's Avatar
I already filled up the tank with fresh gas (on top of 1/2 tank of the old gas?) but will try the injector cleaner.
Vance
Old 03-21-2003, 07:43 PM
GFCC
Jeff's Avatar
Vance, If you have a half of tank of bad gas + half tank of good gas you will probably have the problem continue. You should drain the old gas, fill with new gas and injector cleaner.
Jeff
Old 03-24-2003, 03:22 PM
