-   -   997.2 battery jumper post doesn’t open frunk (http://forums.pelicanparts.com/porsche-911-technical-forum/1031183-997-2-battery-jumper-post-doesn-t-open-frunk.html)
Another911 06-03-2019 01:41 AM
Battery is dead so I connected jump to the fuse box jumper post to open the frunk. I could tell that certain other accessories were being powered,however, the frunk latch was still not activating. I got the frunk open after pulling the wheel and tugging on the emergency release cable (pita)😤. The frunk fuse was OK. Any others have this problem or any suggestions? Is there a wiring diagram showing the accessories that are powered by the fuse panel jumper post?
Mike Billings 06-03-2019 06:46 AM
I had the exact same problem.
Sorry, don't recall definitely what made it open.
I think I had to turn the key to 'run' and then try. Strange.
Marc Bixen 06-03-2019 09:42 AM
Make sure you have a good ground. Try the door latch chrome loop.
rattlsnak 06-03-2019 03:19 PM
Battery jumper wont do it. Has to be a battery or jumper cables.. Never thought to figure out why that is, but it is what it is..
Rodsrsr 06-03-2019 05:11 PM
There should be a cable near the front wheel. Here's a pic of a Boxster but it should be very close.
http://forums.pelicanparts.com/uploa...1559607050.jpg
adias 06-03-2019 08:01 PM
It works this way:
1) 9V battery or larger connected to the fuse panel battery contacts.
2) Open the front trunk with your key remote.
(Note: it is in the Owners Manual).
