69 911E White Smoke from Engine?
See the video at the end of the post.
I purchased a 1969 911E last fall. It was one of the most original I've seen. The previous long time owner was one of the most meticulous people I have ever met, and thus took amazing care of the car. Truly a great person to purchase a vintage Porsche from. The first 6 months I owned the car I drove it multiple times per week, took it on a 1000 mile rally and overall probably put 2500 miles on the car with absolutely no problems at all. I'm in the southwest and the weather heated up dramatically in May and at the same time the car started stalling when coming to a stop. I remembered that the previous owner had said that sometimes the MFI needs to be adjusted for climate. I decided to take the car in to a well known and supposedly reputable early 911 mechanic and told him the issue. After taking it in, the mechanic called me about what he had done thus far and I just didn't get a good feeling from him. Not a feeling that he was trying to screw me, more along the lines of he didn't really know what he was doing. These are the things he did: Assess and check mixture, adjust partial load, adjust idle, replace spark plugs, loosen #3 int valve adjust and sync throttle bodies. At the same time I had him change the oil. After I took it in, there was quite a bit of white smoke coming from the back of the car. The first couple drives I assumed that maybe they dropped some oil on the engine and it the hot oil on the engine caused the smoke. After a few more drives I'm getting concerned. See the video below: |
New-ish 911SC Targa Owner
what does it smell like? Oil burning or something else?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
It doesn't have a strong odor. I'll take it out again a little later and see if I can put my finger on an particular odor.
Mice?
Free minder
White is water, should be gone next time.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Still here
Oh hell I'm sure I could smell it by just watching the video.
Hopefully it's just some cleaning product burning off. Good luck. |
Maybe a small oil leak from the MFI pump. Could be dripping onto the exhaust??? Oil breather hose lose.
