Perpetual Reassembler
2jmotorsports's Avatar
How To Advance SC Dizzy 1 Tooth
1983 SC
I installed a programmable CDI from Parts K l a s s i k and it requires you to purposely advance the distributor 1 tooth.
I did a search and a bunch of people accidentally advance it a tooth, but in order to purposely set it 1 tooth advanced, does the forward tip of the rotor need to sit 30 degrees before the notch on the distributor body?
360 degrees/12 teeth = 30 deg
Thanks in advance for helping me visualize this.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 08-04-2019, 01:38 PM
Upon further thought, since the engine travels 2 rotations for every 1 distributor rotation maybe its:
360*2 = 720 degrees per 1 distributor rotation. 720/12 = 60 deg engine rotation per tooth. Since the distributor travels half the rotation, it should be 30 deg. I think.
Old 08-05-2019, 09:43 AM
RDM RDM is online now
Coram Deo
RDM's Avatar
Because it doesn't have straight teeth, the distributor rotates as you pull it out. The best way to advance 1 tooth is to note where the rotor is pointing once the drive gears are un-meshed, advance it a few degrees (clockwise iirc for an SC), then lower the distributor back down into the hole. The rotor will turn relative to the body of the distributor as you lower it (jus opposite as when you pulled it out).
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 08-05-2019, 12:52 PM
