Initial setup, rear alignment
I've replaced rear spring plate bushings, indexed both plates to 32.2* (should get me close to Euro height) and have the rear suspension hanging at full droop.
Is there a "baseline setup" I can use to adjust the toe and camber cam bolts while at droop?
No engine in the car currently but I want to be able to install the engine and have it driveable enough to get all the major systems function tested. I'd like to get the car sorted, without needing an alignment asap.
1978 SC Targa
Old 06-12-2019, 06:02 PM
In the past I've just put a tire on, jacked the wheel up until it wants to come off the jack stand, then eyeballed the toe. You'll end up way off with uneven camber and toe out of spec, but if you're only going to drive it a little bit to make sure everything is okay then it's not going to hurt anything.
Unless you're aligning with string method, though, I wouldn't want to go far with it until it's professionally aligned.
Old 06-13-2019, 08:22 AM
rsscotty's Avatar
I would set it to max. positive camber and max. toe in, that should be good to drive. You can also verify with toe plates/tape measure and a camber gauge if you want to get closer to specs.
Old 06-13-2019, 08:26 AM
T77911S's Avatar
how much "sorting" are you going to do.
just get it aligned.
find a tire shop that has done porsches and take it there. its usually about $80.
just ask the guy if he has done them.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-13-2019, 10:06 AM
Thanks David,
I'll probably end up doing a string alignment early in the sorting process. Too many possible variables (corner balance, height etc) to want to pay good money for an alignment at this stage.
1978 SC Targa
Old 06-13-2019, 11:14 AM
I was hoping there was a common 'direction' that most rear alignment ends up.
I've seen several threads about "rear alignment maxed out" just couldnt remember which direction was common.
I'll start with max toe and camber, then proceed to a string alignment.
1978 SC Targa
Old 06-13-2019, 11:17 AM
That's a great question.
Car's been off the road, partially dismantled for ~ 15 years.
I've replaced engine, tranny, brakes, suspension bushings, bearings, rod ends etc.
I'm hoping for a short 'sorting' but planning for a project...
1978 SC Targa
Old 06-13-2019, 11:20 AM
Originally Posted by Solamar View Post
Thanks David,
I was in a similar situation as you a while back, having just reinstalled the engine and replaced all of the suspension bushings. What I did was index the t-bars pretty close to where I needed them, a quick alignment in the air, then dropped it to the ground for a drive around the block. Nothing blew up, so I took it by the shop a few days later for final adjustment on height w/ corner balance and full alignment. Probably best if you can do corner balance and alignment at the same shop same day.
Old 06-13-2019, 12:27 PM
