76 3.0 turbo flywheel
I am searching for a flywheel for my engine. I have a 77 euro motor and I need a PN 930.102.201.01. A fellow has offered me a flywheel pn 930.102.201.3R
Is that a compatible flywheel and will a 915 ring gear fit on iti have a Lim Slip 915 trans that I’m going to use on the motor. Eric. 843-298-9677 or ericlunde44@gmail.com |
If you are using a 915 gearbox, you will want a 911 6 bolt flywheel and 915 clutch assembly to match up.
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
+1 This: ^^^^^
'77 S with '78 930 power and a few other things. |
You’ll want everything 915, flywheel, ring gear, clutch package
Bruce |
Scottsdale Arizona USA
Here's what I would run..
911 RSR 915 Flywheel 225mm with ZF Sachs RE Clutch. The other clutch option would be a KEP. The clutch to not to use would be the Sachs Power Clutch or the standard clutch. The original turbos with the 240mm flywheel clutch needs higher clampload and friction surface area. Also the best to avoid aluminum flywheels. ![]() ![]() ![]() ![]()
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design +1 (844) URO-PART // modepw@europartswest.com |
#147 of 2096
I have that 930 flywheel...
Send to me a pm with your email to send you some pictures. Regards.
#147 of 2096 |
