clock
1987 carrera, clock stopped working while driving. I checked, fuses, none burnt
any suggestion? |
They just die. If you had a working clock, you could swap them to see if it is the clock or the wiring. I'm betting it is the clock.
The clock on my '83 Targa was not working when I acquired it. I fixed mine with 2 new capacitors. It's easy. Pull the clock, get the correct capacitors, take apart, R&R them and then put back together. Mine keeps perfect time now....
i was working on one 911 and the clock , i was told did not work.So i have checked and guess what............... the battery was dead;-)
I had to keep it and got new clock for the guy;-) Ivan http://img.pccreation.net/photos/201906142130565168.JPG http://img.pccreation.net/photos/20190614212842655.JPG |
I posted a detailed repair of the 2 capacitors in the SC clocks here. If the 87 clock is similar, that might do it. My fix has been working perfectly for a few years now.
http://forums.pelicanparts.com/porsche-911-technical-forum/874417-911sc-clock-repair-annotated-photos.html |
http://forums.pelicanparts.com/uploa...1560543273.jpg The connector is in the bottom right of the photo, and it has the black wire. On mine the connector was FUBAR, and I had to replace that connector. |
Capacitors.
http://forums.pelicanparts.com/uploa...1560571184.jpg
^^^^^ I replaced these on our clock. All well now. Gerry |
Did it stop working entirely...or did it give the the wrong time by a few hours?
If it's the second case...see mhackney's thread. It worked great for mine. |
clock
it stopped working completely...fuse is fine, power is on, led light is on as well...
clock
1987 carrera....question: when replacing the 2 capacitors, do I have to break and solder the 2 new ones? if yes, please show where this is done on the clock...a picture, if available will definitely help. THANKS!
If the clock won't work at all...it's not the capacitors. Mine would keep good time until it sat in the garage for a few days. Then it would work fine when driving again. Replaced the caps and all was good again. |
clock
so, if it is not the capacitors and there is power, what is it then?
Another option, send it out for repair. I see a major online auction has a listing for repair $130, or any VDO repair vendor. Rob |
Just fixed mine with 100uf 24v polarized caps from Amazon for $5.99 got 5 of them. If anyone needs a couple PM me
Help
http://forums.pelicanparts.com/uploa...1592432377.jpg
Need some HELP.............. Soooo I have a 74 911. Reading through some of these CLOCK repair threads. Mine already doesnt work so why not try and DIY ? stumped after 2 min.... this sucks, and gonna be a long road I'm guessing. Black wire off! Brown wire off! What is that last attached wire? How is it attached? How do I disconnect it? |
Pull the light bulb assembly out.
Sent mine to North Hollywood Speedometer. Works great now.
| All times are GMT -8. The time now is 02:01 PM. |
