-   -   If you could update your 911 to modern spec...what would you change? (http://forums.pelicanparts.com/porsche-911-technical-forum/1032220-if-you-could-update-your-911-modern-spec-what-would-you-change.html)
rennch 06-14-2019 08:20 PM
This is a hypothetical. Meaning, try to answer the question, and not respond with "the 911 is the perfect car and nothing should change....".
If you could update something on your 911 to "modern" spec, what would you change? Examples would be modern wiring and connections (including a modern fuse panel), warning lights/buzzers, comfort items like keyless entry, etc.
Assume the "upgrade" would be done to factory spec, and was engineered like Porsche would have done it. Chip Foose does these kinds of things to his hot rods with modern suspension, switches, AC, etc...
Just curious what minor issues you have with your car that you wish were more like your daily.
Arne2 06-14-2019 08:54 PM
Maybe central locking, but that's about it. I own a '72 911 because I DON'T want all the modern stuff. Doesn't mean that I don't think some of that might make it 'better' or more user-friendly, but I don't want that. I can drive a modern car for that. I own an early 911 because I like the early-car experience.
Bill Douglas 06-14-2019 08:58 PM
Maybe a bit less road noise. Mind you, minimal everything - like sound proofing, makes our cars light and fast.
Jack Stands 06-14-2019 09:21 PM
A bit more modern electronics. Every time I need to swap out a window switch, I wish there was a multiconnector for the wires. A modern fuse panel would be another nice feature.
juanbenae 06-14-2019 10:49 PM
a cup holder.
rennch 06-14-2019 11:01 PM
Originally Posted by juanbenae (Post 10492348)
a cup holder.
Hear hear on that one...
Rawknees'Turbo 06-14-2019 11:03 PM
A fully modern, engine management system (dynamic ignition timing control, knock sensing, AFR and airflow monitoring with compensation adjustments done automatically and on the fly, fly by wire throttle control, ignition enabled clutchless upshifts, etc.) - all the ancient, caveman stuff on these machines is cute, but that's about it. :)
Also on my list would be a sequential gearbox.
madcorgi 06-14-2019 11:03 PM
HVAC. Which I plan to do soon with the electric AC system. Otherwise, the car is perfect for what I use it for.
rennch 06-14-2019 11:06 PM
Highly recommend that AC system.
pmax 06-14-2019 11:08 PM
Rear view mirror which doesn't shake like Shakira.
Originally Posted by Rawknees'Turbo (Post 10492354)
... gearbox.
A drop in replacement for that clunker would be sweet.
rennch 06-14-2019 11:38 PM
Lol!
AndreasK 06-15-2019 02:12 AM
Indicator switch. I dread those moments I have to manually turn of my indicators.
But that´s about it. I have all the modern stuff in my family car.
piscator 06-15-2019 03:24 AM
a cup holder.
What is it with you guys and cup holders? I've been hangin' around these parts for ten years and 'cup holders' seems to be the most talked about performance mod on the board! This is either inside humor I don't get or some kinda fetish! Are we driving these cars? Or taking tea in them? :D
Gordo2 06-15-2019 03:33 AM
Where do you hold your beer while driving? :D
Mine would be self dimming rear view mirror - but I plan to add it.
Quasimoto 06-15-2019 05:32 AM
Not embarrassed to say that I’d replace my 915 with a G50...:/
Aside from that, I’ve had the pleasure of driving a “loaner” 993 the last few weeks and I am in love with how it drives. I’d love to have an impact car with that feel... :)
mhackney 06-15-2019 05:53 AM
Mine would be "headlights off" when I turn off the ignition.
Quickstep192 06-15-2019 06:05 AM
My first add would be electronic fuel injection. I know it’s available, but installation and tuning still seem a bit above my pay grade.
If we’re allowed to venture into unrealistic upgrades, I think I’d add air bags.
jlex 06-15-2019 06:21 AM
I think about power steering every time I park the '88.
ab1752 06-15-2019 07:23 AM
My daily driver is a 2018 BMW m550i. More than a 5 series but not quite an m5 with all the modern features of a car to choke on plus xdrive which was not available on the outgoing m5 . I added a Khule AC system and that's the only system in the 911 I felt needed a bit of help (particularly since it was missing). I like how efficient the 911 was designed, even the quirky HVAC control systems. If I could, I would absolutely drive it daily and part ways with the BMW and all of its modern junk.
speedster911 06-15-2019 08:38 AM
Blade fuse panel upgrade and AC
juanbenae 06-15-2019 08:42 AM
I've been hangin' around these parts for ten years This is either inside humor I don't get
ding-ding-ding! the joke was even old 10 years ago...
Iciclehead 06-15-2019 08:47 AM
OK, I like this list, on my car there will be:
6 Speed G50 with Quaife Limited Slip
Motec engine management (3.4 litre, twin plug, ITB's)
Replacement electrics including blade fuses
More relays in various spots (headlights, brake lights etc etc)
964 A/C with Griffith upgrades
ASP rear suspension and most of the Elephant upgrades
Recaro's....the real ones, not imitation
17 inch Fuchsfelge (so I can get real rubber)
Rear seat delete with built in cup-holders.....
Check my thread out if you want, it is still under construction
http://forums.pelicanparts.com/porsche-911-technical-forum/185692-fitting-6-speed-g50-89-carrera-new-post.html
Dennis
Cory M 06-15-2019 09:24 AM
Air conditioning that works. Basically the only thing that will keep me from driving the 911 is hot temperatures. I suppose solutions are out there now but all cost $$.
Ventilated seats, liked modern cars have, would be nice for the same reasons.
Brighter headlights. I've got a set of LEDs on the way, hopefully a big improvement over the H4s.
Affordable high quality headers for 3.2+ engines with heat exchangers would be nice.
Better selection of performance 15 and 16 inch tires.
mickey356 06-15-2019 09:33 AM
I think Singer nailed it with their approach; classic styling, REAL modern upgrades to HVAC, sound system, electrical, etc....
I would LOVE an upgraded "easy to install" wiring and electrical system, for my 912. I did the alternator install and I feel more comfortable having it in the car over the generator. I'd like to have an electrical upgrade to handle modern demands of charging cell phones, stereo, etc...
nene 06-15-2019 09:44 AM
A modern gearbox...
Even when I had my first 1975 Porsche in high-school (1986), the gearbox did not feel good, notchy and all....
manbridge 74 06-15-2019 10:56 AM
It’s already modern enough.
I would like some sort of hard to disable vehicle tracking system. These cars can disappear too easily....
piscator 06-15-2019 03:58 PM
Thanks, I feel better!
GH85Carrera 06-15-2019 08:44 PM
I upgraded my AC to 4 condensers, and it blows cold air and it is wonderful.
My dream would be a light power assist steering in under 5 mph speeds, and none after 6 mph. And maybe ASB for the brakes for the rainy days.
Total dream is a 6 speed transmission.
The AC made my car drivable all summer. Just today my wife rode with me on a PCA fun run over to a great restaurant and some interesting roads. It was humid, and high 80s and she asked me to turn the temp up because she was cold.
shawn908 06-16-2019 05:28 AM
One change: antilock brakes
Coastr 06-16-2019 09:45 AM
Everyone rags on cup holders but even the closest backroads are a good cup of coffee away for most people. Lots of driving is going along smooth flowing roads to get where you want. Nothing wrong with a water bottle or coffee.
Having said that the duct tape roll on the floor works a treat.
Cairo94507 06-16-2019 11:04 AM
I would want ABS, AC and a force field around the car to protect it from idiots, all kinds of idiots on the road.
Nick Triesch 06-16-2019 11:09 AM
AC, cup holder, a steering wheel that does not look like it came out of an 85 Chev Impala! Hood and engine lid shocks you can get to . Easier access to the air filter.
GH85Carrera 06-16-2019 11:34 AM
AC is easy to fix now. It can be great and blow lots of cold air. Mine is blows cold!
The cup holder is silly. I do bring a water bottle, but I screw the cap on, and put in a door pocket.
ABS is as likely as a 6 speed. Theoretically possible, but not at a reasonable cost. Still it would be nice if it was practical.
pmax 06-16-2019 12:31 PM
Interesting comparison.
Ignoring the cost side (won't be cheap for either!), ABS looks very practical relative to a tranny swap given there's plenty of space in the frunk to add a control/ECU unit with easy access to power. Wheel sensor wiring can be routed to the front, I don't see any practical problem there. However, I can see the liabillity part of any such system as a problem.
BullStandsAlone 06-16-2019 02:35 PM
Anti-theft GPS tracking and full wiring harness kits with easy connectors.
I feel like most other modern upgrades are available.
High Life 06-16-2019 03:57 PM
Nothing.
Its the adventure and the risk and the annoyance of owning a time machine that I paid too much for. It's perfect because of its flaws.
blucille 06-16-2019 04:57 PM
Agree with a lot of this. It isn’t just modern AC and/or heat, it’s ventilation, defrost, mostly vent locations and air movement
But for me, the biggie is modern sealing, windows, ease of rolling up and down, proper sealing for no wind noise, stuff like that.
Iciclehead 06-16-2019 05:23 PM
ABS yes, a big problem as the suspension geometry is all wrong.
In terms of 6 speed, my project car has a 6 speed fitted into a standard '89 (pre-964) without issue. Only thing I have lost is the dual mass flywheel option, but for me, that is not an issue.
Dennis
Geronimo 06-16-2019 05:40 PM
If I wanted a great running, high performance, reliable, durable, comfortable, practical, performance car I would have bought a Vette. ;P
Coastr 06-16-2019 06:12 PM
ABS would need wheel speed sensors and calibration. I wonder if bits from an old Benz might work. You’d want to adapt a system that didn’t have the abs incorporated into everything else and was somewhat standalone. Or maybe just 944/968/964 units would work.
