Help with CA smog troubleshooting
Hi all,
I am having major issues trying to pasa CA smog with my 1988 Targa. 1. Two wks ago I brought in car and it failed smog due to excessively high nox. Two yrs prior thr Nox readings were very low in the 15-16 range. I find out that O2 sensor was u plugged. 2. I realizes california brown wire was unplugged too so i plugged both brown wire and the O2 sensor in and unplugged battery overnight to reset ecu. Replugged battery and drove for about 3 days (50-75 miles). 3. Brought car in for pretest first and it passed with much lower Nox thankfully. And passed all other numbers. So then i had smog guy do official test on same dyno just minutes later. 4. Well this time it failed on Hc and Co. Can you please let me know what u think issue could be? Did i not drive long enough for O2 and dme to adjust properly? Thats what my mechanic thinks. Please see smog results below. Thank you very much! Leon |
| All times are GMT -8. The time now is 11:26 AM. |
