73-2.4
Guest
Posts: n/a
One carb running rich after rebuild
Howdy folks. I have a problem.
I rebuilt a set of 3 barrel carbs and now one is running rich (judging by the sooty plugs) I was very careful with the floats and all other parts. I double checked everything and it all looks to be correct.
Any ideas?
Old 06-15-2019, 01:18 PM
Any ideas?
You have to tune it.
Check airflow balance at first, then turn fuel screw until you reach the lean best conditiin.
If you need more info, please give us more infos.
Carb type, engine specs, jetting and so on.
Old 06-16-2019, 06:44 PM
73-2.4
Guest
Posts: n/a
I did tune it. For some reason I had rich conditions on one carb, no matter what I did. It was very strange. I took it apart and put it back together in exactly the same way I did when I rebuilt it the first time and it now runs lean. No jetting changes. I was initially rebuilding due to the fact that I kept clogging idle jets.
I'll pull them apart tomorrow and clean them thoroughly again. I must have missed something.
Old 06-17-2019, 12:18 AM
1QuickS's Avatar
  • It is easy to install floats upside down which will drastically affect float levels
  • fuel level in float bowls is best checked on running engine using external float level gauge
  • float levels are almost NEVER correct when using the standard gaskets some rebuild kits supply for this
  • tabs where float needles contact have divots in them from wear, these can cause float needle valves to stick open when needles & floats are swapped for location
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 06-18-2019, 10:12 PM
