Replacing clock with GPS Speedometer
Hi,
Bought this on Ebay. 85mm GPS Speedo. Cost approximately 80 dollars Australian (which in US dollars means very little). A little bit of silicon tape in place of rubber around the clock and a perfect fit. Three wires to connect (Positive, Negative, and one for instrument lights). A straight swap for the clock. A 15min job. An addition will be a switch on the positive as it always on to be able to turn the GPS Speedo off when car is parked. Then the trip odometer would zero. Something to cut down the glare would be good too Button on back allows for KPH or MPH. Can also see in picture a laser-printed speedo face. Mine was too cluttered showing both scales |
I like it, pretty slick.
I like it. You did a good job on the original speedo.
I only look at the giant gauge in the center.
And the drunk press once in a while
1986 Bosch Icon Wipers coupe. |
Cool. You have the brand name? Didn't see it on eBay.
thanks Bill for the compliment.
It is a laser printed on standard paper with a paper sealer painted over it. Hopefully it lasts. I would rather use the old speedo but like the GPS speedo there as well. I did a search for 300km GPS speedometer on ebay.com and found it. Make sure you get the one with the black bezel. |
I plan to install a GPS speedo in my project. it originally had a mechanical drive speedo and older 915 gearbox.
I now have a short bell housing 930 gearbox. but depending on tires, gearing, etc had concerns about being able to calibrate an elec or mech drive speedo. I want to mount in the location of the speedo and a AFR/boost gauge in the clock position. thanks for the post.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
Cool idea. I did a GPS sensor to my stock speedo, and kept my clock.
I have a 3D printer/laser engraver. Would love to know how you made a Speedo face with a laser. Hmmm.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Cool ! I was thinking this weekend on how great a thing like this would be instead of the non working clock.
There is several versions is see.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
I would rather be driving
Just follow the lead...
search 85mm GPS speedometer on eBay. tons of listings.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Go to amazon a search for an auto meter gps speedometer sensor. I have also posted a link here before in other threads.
