| Registered Join Date: Jul 2000 Location: Bend, OR USA
				I snapped Injection Pump Belt!
			I just learned that my car is not running because the belt that runs the injection pump snapped!  This would make sense. I did a bunch of work and put it all back together. It ran fine for a few minutes and then died. Since then, it has not started. I backtracked all of my steps, checked all electrical connections, timing, etc. Then I notice this belt hanging in the breeze not attached to anything. How often should this belt be changed. Hard to replace?? Anything else I should think about??? Thanks. | ||
|  03-22-2003, 08:52 AM |
| Registered |
			Two-hour job if you clean all of the sheet metal before buttoning things back up ... Get a spare belt ... Autozone doesn't carry them! Actually, they probably don't need to be replaced more than every 10 years or so, but anual inspection for cracks is a good idea. I replaced mine at 60,000 miles due to visible cracks.
				__________________ Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' | ||
|  03-22-2003, 08:58 AM |
| Author of "101 Projects" |
			Make sure that the timing marks are properly aligned on the belt.  You may also have to prime the pump (cranking the engine for a bit) before it can start.  See here for more details: http://www.pelicanparts.com/techarticles/911_MFI/TipMFI.htm -Wayne
				__________________ Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports | ||
|  03-22-2003, 09:00 AM |
| Registered Join Date: May 2000 Location: Los Alamos, NM, USA
			Do you realize this belt is a toothed timing type belt; the pulleys need to be correctly positioned when reinstalling the belt.  Jim
|  03-22-2003, 09:02 AM |
| Registered Join Date: Apr 2001 Location: Linn County, Oregon
				 | Quote:
|  03-22-2003, 11:18 AM |
