A/C Relay Wiring -- Need Help!
The a/c relay in my 1979 SC's smugglers box has no ground connection. Apparently it's not supposed to. That’s the way it came from the factory and that’s how it’s shown in the Bentley manual.
So how does a relay work without a ground? If I detach the yellow wire at pin 86 and substitute a separate ground, my a/c fan switch and temperature switch operate the evaporator fan and power the compressor perfectly. But that's NOT the factory wiring! I AM confused! On page 970-12 the a/c wiring diagram shows the a/c relay (pin 86) connected to +12v from the ignition switch (terminal 50) – which the manual calls “starter”. This is a yellow wire that is connected to the yellow wire feeding +12v to the fuel pump relay. On pages 970-2,3 the Bentley manual shows this yellow wire from the ignition switch (terminal 50) to the fuel pump relay (terminal 87) and it’s connection to the a/c relay (terminal 86) . This yellow wre is also connected to the heater ventilation switch. O.K. This makes perfect sense. Turning the key in the ignition switch sends +12v power to the a/c relay to close the circuit and run the air conditioning. On a standard 5 pin Bosch relay, connecting power and ground to pins 85 & 86 closes the relay and connects pins 87 & 87A to pin 30 – right? Here’s where it gets weird. The black wire at a/c relay (pin 85) is not a ground! It’s connected to +12v at the ignition switch (terminal 15) alongside the yellow wire. Like the yellow wire it is switched on only when the ignition is in the run position. This black wire at a/c relay (pin 85) is shown on Bentley page 970-4. A red/black wire starting at the ignition switch (terminal 15) supplies +12v to the tachometer and to fuse 12. This red/black wire then jumps to fuse 11 - supplying that fuse. At fuse 11 the red/black wire also connects to black wire bringing +12v to the a/c relay (pin 85). So the question, once again – how is the a/c relay supposed to work when pins 85 & 86 are both connected to +12v from the ignition switch??? Shouldn’t one of those pins be connected to ground? To answer that question, I disconnected the yellow wire from the a/c relay (pin 85) and fed it a separate ground. I heard the relay ‘click’ – turned on the fan switch - and watched the evaporator blower run perfectly! Since the fan switch feeds +12v to the a/c temperature switch, that also worked perfectly; sending +12v to the compressor. So it seems to work when it’s wired WRONG!!?? Because that’s not the way the car was wired or the way it’s wired in the Bentley manual. I’m missing something, but I sure don’t know what. To say that I’m perplexed would be the understatement of the year! P.S. I’m starting this as a new thread to make it easier to find by future travelers. |
Not near my vehicle today so I can’t check, but is the yellow wire grounded in the run position on the ignition switch this may be Via the ignition switch itself being mounted to a steel dash plate?
I noticed a what appears to be a break with symbol to ground and a diode symbol on the factory diagrams? Easy enough to check if yellow is grounded with key off which is the same contact position as in run. Yellow wire should only see 12vdc in the crank position. This would stop power flow at the A/C relay coil as both sides of the coil would see 12 volts. Thereby not allowing the relay to operate stopping the compressor from running while cranking the starter. I have a very strong love/hate relationship with the Porsche electrical engineers.... Especially the ones assigned to drawing the current flow diagrams... |
They might be using the starter as the ground path for the AC relay.
The starter isn't powered in run and there is no break between it and the AC relay rtn. |
Grounded through the starter solenoid is a possibility.
Dan, thanks for your contribution! They could have used the starter for ground. But there’s no ground wire in smugglers box. Just the four wires described below.
Dennis, Thanks for your help here and in the other thread! I’m certainly learning a lot about DC electrics! I thought you might have nailed it with your ignition in the run position idea, but I just tested it and it doesn’t seem to pan out. :-( The Porsche owners manual describes four positions for the ignition switch – 0,1,2 & 3 – respectively. 0 = steering wheel locked, all circuits through the ignition off 1 = steering unlocked, all ignition circuits on accept brake warning lights, turn signals, back-up lights and fresh air blower. 2 = steering unlocked, all circuits on 3 = run or ‘starter’ position, all circuits on, except headlight and wiper motor which are temporarily interrupted. Ignition switch returns to position 2 once the car has started, all circuits on. In my car: Yellow wire at a/c relay pin 86 is hot in ignition switch positions 1 & 2 – but not 3 Black wire at a/c relay pin 85 is hot in ignition switch position 1 & 2 – but not 3 There are only four wires at the a/c relay. Red/White at pin 30 is always +12v hot. It’s the input wire from the fusebox that we want connected to the Red wire at pin 87 – when the relay operates and closes it’s internal switch. That leaves the Yellow at pin 87 and Black at pin 85. But both are +12v !!! That’s the way Porsche did it for whatever reason. It’s not unique to my car. I’ve had this Porsche for it’s entire life. None of the wiring has ever been fixed or fiddled with. So it’s not a goof made somewhere in it’s lifetime. Even so, I have now read dozens of internet pages on connecting a 5 pole Bosch relay and they ALL show a ground at pin 85 or 86! I’ve also tested several new 5 pole relays in my car. Wired with a ground in the yellow wire’s place at pin 86, the a/c system runs normally – as the dozens of internet pages would expect. Wired the factory way the relay fails to function because both the yellow and black wire carry +12v!!! And even more weird, the factory wiring must be ‘correct’ because the a/c did work for years. This is maddening!! |
Disconnect the yellow wire at the firewall from the A/C wire to relay to test for ground on it in position 2. Check the non A/C wiring side.
You will see 12 volts on both sides of the coil when in position 2 or 3 when hooked up normally as the coil does not consume the voltage going through it. You need to isolate the yellow wire from the circuit to check for a path to ground with the wire to the relay disconnected. |
Also there is the possibility it is FM performed by spotted Unicorns... :)
FM ( as in F'ing M) LOL - haven't heard that in a while.
I don't have a 79 dwg, but going by an '84, and from the Bentley no less (which isn't necessarily a good thing), this figure was what I was using. I don't think I have to hi-lite it for you to see what I mean. edit - am interested in what he gets when he isolates ylw from pin 85 and chks it to gnd also, this will work if the AC relay R is much larger than the starter resistance. zany http://forums.pelicanparts.com/uploa...1560909721.jpg |
1987 factory schematic shows similar.
note that ref flag K45 goes to K21. I could be wrong - wouldn't be the first time. Seems noteworthy that they'd appropriate the starter wiring like that when it's not being used for it's original intention. http://forums.pelicanparts.com/uploa...1560910397.JPG http://forums.pelicanparts.com/uploa...1560910397.JPG |
The way things go around here, this is a strong possibility! :-) This morning I'll test the circuit as you guys suggest and report back. I sincerely appreciate the help! |
Dennis and Dan,
Again thanks for your help! Here are some photos and test results. The first photos are the yellow wires at the firewall. Testing continuity (ignition in position 2) between these wires and the yellow wire in the smuggler's box (a/c relay pin 86) showed continuity with the thin wire in the lower right. http://forums.pelicanparts.com/uploa...1560969778.JPG http://forums.pelicanparts.com/uploa...1560969778.JPG http://forums.pelicanparts.com/uploa...1560969778.JPG Checking for continuity between these yellow wires and the battery negative terminal (ground) showed continuity between the battery and the yellow double wires in the upper left -- with the ignition switch in either position 1 or 2. http://forums.pelicanparts.com/uploa...1560969778.JPG http://forums.pelicanparts.com/uploa...1560969778.JPG There was no continuity between the battery and the yellow wires upper right or lower right. http://forums.pelicanparts.com/uploa...1560969778.JPG http://forums.pelicanparts.com/uploa...1560969778.JPG Next... |
Testing for voltage on these yellow bulkhead wires showed +12.7v on the ever-popular double yellow wires on the upper left -- with the ignition switch in position 2. And zero (0) voltage on these double wires with the ignition in position 1.
http://forums.pelicanparts.com/uploa...1560970720.JPG http://forums.pelicanparts.com/uploa...1560970720.JPG Curiously, the single yellow wire (upper right) showed zero (0) voltage with the ignition in position 1 and in position 2 flickered between zero (0) and +1/10th volt. An anomaly of the meter, maybe? http://forums.pelicanparts.com/uploa...1560970720.JPG http://forums.pelicanparts.com/uploa...1560970720.JPG The thin yellow wire (lower right) that we now know is the wire to the a/c relay in the smugglers box showed no voltage in ignition positions 1 or 2. http://forums.pelicanparts.com/uploa...1560970720.JPG All connected back together, the thin yellow wire shows +12.7 v http://forums.pelicanparts.com/uploa...1560970720.JPG http://forums.pelicanparts.com/uploa...1560970720.JPG And, the black wire in the smugglers box that connects to the a/c relay (pin 85) also shows +12.7 which originates at fuse #11. http://forums.pelicanparts.com/uploa...1560970720.JPG So I still don't know how the a/c relay get ground, but something did occur to me. The engine and transmission are out of the car. The starter and starter solenoid are sitting on my bench. Maybe I need to find the yellow wire that connects at the solenoid and ground it? Thoughts? Thanks again! |
If you short the starter yellow wire straight to ground, do NOT turn the key to position 3 this will be a no load short on the yellow wire through the ignition. this is an un-fused circuit and you will let the smoke out of your wire harness.
I think this is the point, one side of the starter (solenoid) is already grounded.
If I read the schematic correctly, the starter gets its power via the yellow wire when the ign is in start. When the ign is not in start, the ylw wire is essentially dead, and the AC relay uses this 'dead' line to go thru the starter (solenoid) to ground. I have to run out the door right now but I have some other comments. Also, I am just offering an opinion from what I read on the drawings, but I would defer to others like Tim who have much more background/familiarity. You mentioned the BLK on AC relay pin 85, I thought fused pwr went to pin 86 and the yellow wire went to pin 85? According to the dwgs anyway. Yes, if eng and starter are out, you're not going to measure a path to gnd from the AC relay as it is right now. If my reading is correct, and if everything was in the car (starter, engine etc), and you removed the yellow wire from the AC relay and measured it to ground, I would expect you to see close to zero ohms (or whatever the low starter resistance was). |
geez, I know I said isolate the circuits, but you didn’t have to take the car apart!!!
On a serious note: Didn’t know starter was removed. Tests you did do confirm the theory for ground at the starter . Much better results would be found if car is fully assembled on the circuits being checked. :) |
yellow wire
I posted this old thread from this this forum before, I believe it addresses your concerns and answers them - especially post #7. I have an SC and have studied the wiring quite carefully - the AC relay gets its ground from the starter when the starter in not engaged.
When the starter is engaged there is no ground provided and the a/c fan is disengaged during engine cranking so as to reduce current draw at that time. The link below explains this far better than me. Hope this helps http://forums.pelicanparts.com/porsche-911-technical-forum/638081-yellow-wire-terminal-50-starter-c-relay-issue.html |
76FJ, I will heed your warning, thanks very much!
Dhan, I did a lot of searching in the archive, but somehow missed the thread you posted. Thanks! Dan, your comments are helping me grasp all this and I really appreciate it! I’m sorry if I’m a little slow, but I was an English major! ;-) In my car the black wire runs to pin 85 on the a/c relay. The diagram in my Bentley shows this to be correct. The black wire originates at fuse 11, but I’m not sure if it’s connected upstream or downstream of the fuse. Today I also discovered that the yellow wire that attaches to the starter motor solenoid runs to pin 1 on the 14 wire terminal block on the back of the engine compartment fuse block. I think that means that the solenoid is energized from that pin 1. If that’s correct, the yellow wire to the a/c relay must tie in somewhere before that pin 1. I’m going to read Dhan’s posted thread to see if there’s something about this there. Dennis, I don’t think there’s an adequate emoji to capture how hard I laughed at your quip! That was very funny! I have no doubt that you and Dan are right about this circuit. Even with my limited knowledge, it seemed from the outset that the yellow wire HAD to be a ground. I must say though, I am having difficulty visualizing how this “now it’s a ground, now it’s not” circuit works. And more difficulty imaging why Porsche would do it this way. After all, the a/c relay is mounted on a bulkhead, why not pick up ground right there? I think you said something about ensuring that the a/c didn’t run when the starter was operating, but I can’t quite grasp how this setup accomplishes that. Once again, thanks to you and everyone for your generous help! |
nocarrier wrote this very helpful explanation in the thread dhan posted.
"I think this issue is a major contributor as to why so many of us are having starting and a/c problems. I thought about it for a while and all I can come up with is............. As electricity follows the path of least resistance, the yellow wire acts as a ground for the relay in the smugglers box when it is not energized by the ignition switch. Since the yellow wire terminates at a coil (the starter solenoid) it is ultimately (other than some windings) a direct path to ground. When you turn the key to the start position, the yellow wire is energized and the current flows directly to the starter solenoid. There must be a diode in the relay to prevent this current from reaching the black wire through the relay in the smugglers box causing a short. If this is how this is supposed to work, I am proposing disconnecting the yellow wire in the smugglers box and running a proper trigger to ground connection. " I think he's right about the diode in the a/c relay. My a/c relay is original to the car. The relay closes only when ground is supplied to pin 86 (yellow wire). It does not close if I swap the +12v black wire to pin 86 and then ground pin 85. Do any of you guys agree with his proposal to remove the yellow wire and supply pin 86 with an independent ground? |
yellow wire
In the 2011 link that I attached, "Rick 1" stated the following -
"One side of the relay coil goes to hot and the other to the starter terminal. When the ignition switch is not in the start position there is essentially zero volts on the solenoid terminal and the relay coil is energized by the current flowing from the battery through the realay and through the starter. The current to close the relay (and limited by the relay coil resistance) is minuscule compared to what it takes to pull in the solenoid. When the ignition is in the start position there is 12 volts on the starter solenoid terminal. With 12 volts on both sides of the AC load reduction relay there is no potential across it to make charge flow and the relay turns off disabling the AC and whatever else when the car is cranking". I think that he had some good info above. Hope this helps. Dave |
When cranking the starter, the 12 volts to the A/C relay via the yellow wire does nothing as it is at the same potential as the 12 volts on the black wire. Not a dead short as there is no path to ground for the current to flow to.
It is just like joining 2 loose wires attached to the same battery positive terminal to each other, nothing happens until they have a path to ground. No diode needed. A separate ground will defeat the designed feature of stopping of the A/C from running while trying to start the car. When what it wants is all available electrons going to the starter... (CCA rating) |
Dave & Dennis,
Gentlemen, thank you for your patience in helping me to understand this! The function of this yellow wire has been a real brain teaser for me, but I think I’ve learned quite a bit from working on it. Rick 1’s comments from the other thread are excellent! When something complicated is restated in several ways, it helps to break through my foggy comprehension. For me, that’s what makes everyone’s contributions to these threads so important! My, hopefully, last query for you is: What will happen if I connect pin 1 on the 14 wire connector (located at the backside of the engine compartment fuse block) to ground? With the engine in the car, a yellow wire from this pin 1 connects to the starter solenoid. Am I correct that this pin 1 should be +12v hot when the ignition is in start position? But (because it’s connected to the starter) becomes the neutral ground for the a/c relay in any other ignition position? If I run a test lead from the battery negative post to this pin 1 will the a/c relay function as intended? Or would this cause the fire 76FJ warned against? If it’s safe to test the circuit in this way (maybe with an in-line fuse) I’d be able to see how this works and put the whole subject aside until I get the engine back in the car. Again, thanks for your help! |
yellow wire
If I am correctly understanding your question, you want to ground the side of the 14 pin connector that comes from term 86 at the ac relay. I may be incorrect but it seems this would disable the function that cuts out the ac circuit while the engine is cranking, thus taking voltage away from the starter during cranking. I do not remember which side - male or female - of the 14 pin connector comes from the ac relay. If you accidentally ground the side from the starter you will have a dead short when the starter is cranking causing a fire.
I may be missing something but what is the reason driving your intent to modify the factory electrical system. My 82 sc is wired as factory and functions as it should. As I said, I may have missed something earlier in your post. Hope this helps. Dave |
Don’t do it (ground the yellow at the 14 pin), your car won’t start. You would have a dead short to ground in the crank position every time you try to start the car!!!
A new through body harness is around $900, you would need one after trying to start the car with the yellow wire grounded.... maybe even a new dash harness that is more$$$ Just leave it as designed. It works. |
Dave & Dennis,
There is NO engine, starter, starter solenoid, yellow solenoid wire, or transmission in the car. So, no worries. The car's not going to start no matter what I do! I’ll be putting it back together, as it was, with no changes to any wiring. Although I did mention the possibility of grounding the a/c relay inside the smuggler's box, I now understand that this would disable the a/c cut-out during cranking and is NOT a good idea. What I want to do, is a quick experiment to see the circuit ‘in action.’ I want to (just for a minute or two) run an alligator clipped test lead from pin 1 on the 14 wire connector on the back of the engine compartment fuse-block to ground. If the ignition switch remains in the run or off position, when I do this, it should be a safe test -- I think. Grounding engine compartment pin 1 (temporarily) should provide ground to pin 86 on the a/c relay, through the yellow wire running through the firewall. This should trip the relay. I just want to test this to see if my understanding is correct. With the (temporary) test lead removed from ground and the ignition in the ‘start/crank’ position, there should be +12v at pin 1 in the engine compartment. In this condition, a/c relay pin 86 will also be +12v hot. This ensures that the relay can’t trip and prevents the a/c from using energy when the engine is starting. I'd like to see this, on my meter, as well. This is what you guys have taught me and I very much appreciate it! I wanted to see this work, in the car, even with the engine out. That’s why I wanted to set up a test lead to temporarily ground pin 1. If this is still a bad idea or if my understanding is incorrect, I hope you’ll let me know! Thanks, as always! |
I hesitate to post this because I don't know the '79/CIS electrics in this area.
And I think others may be reluctant to give a thumbs up lest something goes bad. Some of us initially assumed that the car was intact, so there's that unknown. You would need to verify that any wires that are "always hot" were completely isolated / not touching anything. So personally I don't feel confident in giving you a yes. You'd have to be the judge there. I have another minor concern below. It would be safer in my mind to just put an ohmmeter from the relay hot side to pin 1 - you should measure 50-200 ohms (the AC relay winding) and whatever that part of the harness wiring resistance is. If you take the powered leap, still do this first because you want to make sure you have the right pins. Barring any objection from others and in consideration of doing the above, if you choose to proceed, you must ground pin 1 and verifying it with an ohmmeter that it was now grounded at the relay itself ... before putting the key in run. This would be done to ensure that there was no voltage on the Ylw wires (because it is essentially grounded to 0V) which reduces the risk of something else happening wherever the other yellow wires are if they were to be at +12vdc. This is due of course to many of the yellow wires being common to each other. In cars with a DME for example (motronic), if the engine were removed and you did this test by applying juice before you simulated a ground on pin 1, the DME (which would be on) would see the +12 on the ylw wire as starting voltage which would trigger the it to turn on the DME relay and thus the Fuel Pump. Not good (if there's gas in the tank and the lines are disconnected). I don't know the equivalent FP ckt in the 79 CIS or if the yellow wire is involved. But that problem should be eliminated if you ground pin 1 first (and pop the FP relay and fuse). These are the risks as I see them anyway - a loose hot and an un-grounded or hot yellow wire. I don't know what to tell you, I understand your motivation, but I am not 100% on this, and I figured you deserved some response. |
I can assure you the yellow wire on the male pin one of the 14 pin connector on the rear fuse panel runs directly to the yellow wire connection area at the dash harness 6 pin through body connector.
I have built numerous through body harnesses for multiple years of 911’s and they are all the same. I advise not to do that test just because it is easy to go to crank.... |
I defer to you on this Dennis, but I am curious about what you mean by 'go to crank'.
Dan & Dennis,
Thanks for getting back to me, it’s very much appreciated! On your advice, I WILL NOT ground pin 1 on the 14 wire harness in the engine compartment. I do think it would be safe, particularly after the testing Dan suggests, but it's not necessary. My goal has been to resolve my mystery and learn how this works. That goal has been met and for that I thank you! I’m not so impetuous that I need to take this any further when there’s a chance that doing so is potentially hazardous. BTW: I think what Dennis means is that it would be too easy to inadvertently turn the key to the 'start/crank' position and cause damage. I suspect an inline fuse would mitigate the threat, but again, the test is not essential and is easily skipped. Dan I’m especially indebted to you for your careful writing, which has helped me understand more than just the immediate issue. I plan to make the ohmmeter tests you suggest and we’ll see what that tells us. I won’t get to that for a couple of weeks because I’m off to my family’s annual get-together in the grand state of Maine! I had hoped to have the car done by now, but you all know how that goes! When I get the a/c up and running and the a/c relay functioning as it was designed, I’ll post here to let you know. Thanks again gentlemen, I could not have gotten to this point without your help! |
For Dan,
As Robert clarified above, I meant turn the key to the crank/start position on the keyed switch with the grounding jumper in place on the yellow wire at pin 1 of the 14 pin connector. Thereby impressing the entire unfused 12vdc current available from the battery on the grounded yellow wire, creating a dead short through the circuit, “Letting the smoke out”.... The ignition switch has unfused power directly from the battery that is in play when in the crank/start position. |
Robert - You're welcome. I waited a day before sending that response just in case you got a better answer, and then I let 'er rip. Good luck and yeah, let us know - Enjoy your vacation!
Dennis - Aha! (duh) thanks, yes, one 'key' risk too many. |
| All times are GMT -8. The time now is 11:24 PM. |
