Targa_PB_78_SC
JB Weld removal with heat?
So I’ve patched my case defect in SITU about 6 times. Think it might still leak. With the engine out I’m wondering if using heat (propane) to remove the JB weld to try a fresh seal is wise?
Propane is a good idea. If using MAPP don't heat it for too long. I've melted aluminium with MAPP
The 9 Store
We remove head studs with mapp. 2-3 minutes gets it hot but no where near melting or damaging the case. We use it on mag too.
All used parts sold as is. |
Upper cylinder head steel studs........
Mike,
Are you replacing also the upper cylinder head studs? What brand have you selected? Thanks. Tony |
Wire brush it down, carb cleaner and reapply JBWeld
Also opposite side under the oil cooler is matching potential leak. Bruce |
Heat worked for me
81 SC 3.8 Conversion 2017 Macan S INSTAGRAM @tail_spinz |
Mighty Meatlocker Turbo
Heavy duty paint strippers with methylene chloride remove JB Weld (as does acetone, but it takes a lot longer if the JB can't be submerged in it).
If you have the case half out, why wouldn't you get it professionally welded? JB weld is a half ass solution for something like that.
New-ish 911SC Targa Owner
anyone use those aluminum brazing rods here instead of JB weld? Seems much more permanent of a repair.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Crotchety Old Bastard
It would be a tragedy to put the engine back together without taking the opportunity for a permanent fix. Have it professionally welded and never worry about it again.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Targa_PB_78_SC
,attempt at JB weld. I’ll look around to see what I can find. I think I have the time to do this, certainly can afford it too. Thanks |
