-   -   Is the 911 CV Boot the same as a VW bus one? (http://forums.pelicanparts.com/porsche-911-technical-forum/1033093-911-cv-boot-same-vw-bus-one.html)
MadeofOak 06-25-2019 09:09 AM
I know 'similar' isn't the 'same.
But they are both made by Empi (cheap), just wondering if they are the same. (I'm ordering one for ..science). The Pelican one is on order (waiting...).
http://forums.pelicanparts.com/uploa...1561478903.PNG
Mark Henry 06-25-2019 09:50 AM
They're cheap junk, you'll be lucky if they last 1-2 years. Plus I doubt if they fit, have 6 holes, etc...
MadeofOak 07-03-2019 03:12 PM
Same manufacturer as the one listed here, Empi.
And.. Porsche is also 6 bolts.
And finally, they fit perfectly. In fact...drum roll, same part.
3rd_gear_Ted 07-03-2019 07:33 PM
$.02 worth
The Empi's have 4 rubber folds in the boot portion, the Porsche ones have 3 folds.
For track use the Empi's are better due to the axle angles allowed.
MadeofOak 07-03-2019 08:55 PM
For Canadians, cip1 has cheaper delivery as well. Good point on folds.
MadeofOak 07-03-2019 08:59 PM
http://forums.pelicanparts.com/uploa...1562212703.jpg
Same same!
Adrock 07-03-2019 10:10 PM
I assume the actual bearings/internals differ for the porsche version though?
Canada Kev 07-04-2019 05:28 AM
Not much in the way of bearings in just the boot... ;)
faverymi 07-04-2019 06:20 AM
Most people over fill them with grease and they deteriorate. Regardless of the brand.
They need the right amount of grease. And they'll go a long way.
Adrock 10-13-2019 04:56 AM
Hilarious! :rolleyes:
My question was actually referring to the actual CV joint.
Plenty of information to say that the boots are the same for Porsche/VW Bus, but - could the CV joint also be the same? They certainly look very similar.
