-   -   8 Pin CDI Rebuild (http://forums.pelicanparts.com/porsche-911-technical-forum/1033319-8-pin-cdi-rebuild.html)
911hunt 06-27-2019 04:50 PM
8 Pin CDI Rebuild
I am almost finished with my 76 930 motor and need to sort out ignition. I have looked at the usual suspects that rebuild CDI boxes but many don't support the 8-pin CDI boxes. Does anyone have a recommendation for a trusted vendor to go through my 8-pin CDI? Thanks!
MBAtarga 06-27-2019 05:41 PM
Did you contact Pelican user ischmitz?
Flat6pac 06-27-2019 06:41 PM
Years ago,
I needed my 76 turbo 8 pin rebuilt and sent it to Zims in Texas
Try Bob Ashlock, on PP.
Bruce
gumba 06-27-2019 07:14 PM
Bob Ashlock rebuilt my 8 pin cdi a few years back.
Jonny H 06-27-2019 11:16 PM
We can put our modern electronics in your 8 pin case or we have a complete 8 pin replica box.
john walker's workshop 06-28-2019 04:59 AM
I used a 6 pin on my 77 930. Eliminate the two wires that go to that condenser looking module attached to the panel, get a 6 pin plug and swap the wires from the 8 pin plug in the correct order.
blucille 06-28-2019 05:45 AM
+1 for Bob Ashlock. Good guy, great work, fair prices, quick turn-around. What more could you ask for?
Tom F2 06-28-2019 06:47 AM
Another vote for Bob Ashlock.
digitaldgp 06-28-2019 08:04 AM
Another Vote for Bob Ashlock, he just finished my CDI.
mysocal911 06-28-2019 08:29 AM
Those Bosch CDI units are very reliable and rarely if ever fail. Many assume that this CDI has failed because it doesn't buzz
like the 3/6 pin Bosch units. Do a Google search for its part numbers; 0 227 300 002, 0 227 300 003, various rebuilders.
Typically the problems are; a bad 12V power input or a bad distributor signal, both easily checked with a volt/ohm meter.
Avoid using the Bosch silver coils with any CDI units
mysocal911 06-29-2019 07:52 AM
Interesting read here; http://forums.pelicanparts.com/porsche-911-technical-forum/203100-6-pin-sc-turbo-cdi-unit-repair-documentation.html
Jonny H 06-29-2019 08:00 AM
A 6 pin box won’t drive an early Turbo tacho. You’ll need one of Bob’s adapters too.
911hunt 06-30-2019 01:23 PM
It looks like Bob is the go to guy. Thanks for the recommendations!
john walker's workshop 06-30-2019 02:20 PM
Seems to drive mine.
Jonny H 06-30-2019 02:57 PM
Check the year of the tacho, probably a later one.
8 pin boxes produce a 400V positive spike to drive the tacho. The tacho on the early Turbo is therefore more like a 69/70 tacho (that was driven direct from the coil). 6 pin boxes are just 12v so will only drive the low voltage ones (as fitted to the later Turbo).
8 pin boxes will drive tachos designed for 12v but I can’t imagine it is very good for the tacho!
john walker's workshop 06-30-2019 05:26 PM
Thanks, I'll check the date stamp.
porschetub 06-30-2019 11:28 PM
Bob is a great guy to deal with,happy to help me with my ignition setup also.
911hunt 08-27-2019 04:28 PM
I received my box back last month from Bob an dit is an absolute work of art!
dicklague 08-27-2019 10:29 PM
the Bosch CDI is a 50 year old design with 50 year old components.
A modern CDI is much much better. Even having a soft rev limiter is great plus more spark.
Best day of my life is when I dumped that old Bosch!! My 911 came alive with a good modern unit.
I know you won't agree. Loren
