-   -   Should I buy a 911SC? (http://forums.pelicanparts.com/porsche-911-technical-forum/1033378-should-i-buy-911sc.html)
ksluna 06-28-2019 10:39 AM
I'm in the market for a G-body 911.
I really don't care about the 915 vs G50 transmission as I've test driven an 86 and I liked the 915.
This would be a weekend driver.
Initially, I was only set on an 84-89 Carrera, but lately I've been seeing some good SCs. I know this topic has been beat to death but maybe my situation is different.
I've read countless threads about CIS vs Motronic and really, the threads on here is what swayed me to only opt for 84+.
I am not a mechanic by trade, I do like to do the basics on my cars but the CIS just really scares me. Outside of it being really finicky, I've read that parts have become scarce.
If I were to buy an SC and have the CIS tuned by a reputable shop, would it be "set" for the most part without too much adjustment or tinkering from me? And if so, would I have a hard time finding parts related to the CIS?
joegt3cup 06-28-2019 10:52 AM
911sc
I have owned many many cars including many Porsches with only a very few that I kept for a long period of time one of them was a 79 911SC owned it close to 10 years and it was bullet proof, it was one of my favorites.
Good Luck
Joe
pampadori 06-28-2019 10:58 AM
I only lasted about 1 year on CIS before I threw in the towel and went for EFI. Cracked airbox vacuum leaks is what pushed me over the edge.
Should I have started with a 3.2? hard to tell. I wasn't able to be picky when I was shopping. My budget was only enough for a **** heap so I probably would have had a project no matter what generation I bought.
ksluna 06-28-2019 11:00 AM
I like the idea of a revvier, lighter SC but it's just that I'm what I would consider a "youtube mechanic" what takes someone maybe 1 hour may take me 2. Just afraid the CIS may be more than I can handle.
Also I've read NUMEROUS threads of people suggesting SC owners to buy all the CIS parts while they can before they become too scarce.
Trackrash 06-28-2019 11:03 AM
It should be pointed out that the CIS comes in two varieties. '78-79 had the large ports and no lambda control. The '80-'83 had the small ports and extra controls.
Most people, I have been told, would prefer the '78-'79.
However I would hope others would chime in about their experiences.
As much as some people will discount the CIS, there are those who use it with good results. Back dating the exhaust will really wake up these motors, if you don't need t worry about smog.
walt 06-28-2019 11:06 AM
I've had my 82 with CIS for almost 20 years, just about bulletproof. You won't go wrong with either of your choices given they were properly cared for.
ksluna 06-28-2019 11:06 AM
I live in TX so no need to worry about smog.
As far as performance, I don't really care too much about SC vs 3.2. If I wanted a faster car I would just get a new 911
The SC I'm looking at is a '79. Are the ones without the lambda control much easier to work on and diagnose problems?
ksluna 06-28-2019 11:07 AM
Outside of reliability though, does it require a lot of adjustments depending on the season/weather?
Cory M 06-28-2019 11:21 AM
SCs are great cars. I've seen 3 or 4 solid cars for sale lately for reasonable prices too. I wouldn't worry about the CIS vs Motronic. Both are set it and forget it type systems, either one can have issues but in general are very reliable.
ramonesfreak 06-28-2019 11:27 AM
Bought my car 12/13 years ago. Loooong ago I had a shop set the mixture. Since then, never touched it. Car runs perfect. But, every one of these cars are different at this point as far as parts worn out etc.... Maybe I got lucky.
I always use non ethanol gas
Yorkie 06-28-2019 11:36 AM
I would be more worried about the case studs snapping. They failed on my ‘78 and 10 years ago it was a $5k job with me pulling the motor. Get a ppi
ksluna 06-28-2019 11:37 AM
Might be a stupid question but I thought you had to constantly adjust the mixture with CIS? So when people like the above poster who "threw in the towel" with CIS, is it not necessarily for adjustment but the wearing down of parts that need to be replaced?
Jack Stands 06-28-2019 11:46 AM
The CIS is really a mechanical system, so once it’s set, it should be quite reliable. All the controls for cold starting, etc. can cause some issues, but it’s really quite a simple system. Just don’t let it sit unused so the fuel gums up the metering rod.
ralfoto 06-28-2019 11:55 AM
I am a new owner of 1981 sc.....love it and yes it needed to have some CIS adjustments done but from all I can tell from others who own them they are bullet-proof once set up and if you drive them. I think more important is the PO care of the car, history etc......parts are parts and they wear out but how someone cares fro their care is most important.
I have had numerous Alfa Romeo GTV's from the 1970's with the SPICA injection system.....everyone was "afraid" of them but once set up correctly they proved to be super reliable....and never had problems.
Craig_D 06-28-2019 11:58 AM
I've had my '78 SC for over 10 years and 30,000 miles without a hitch. I have a number of friends with SCs that have also never had a problem. In fact, it wasn't until this thread that I see people "think" there is a problem with the CIS on these cars. Perhaps people, such as pampardori who only had enough money to buy poor condition machines, are confusing vacuum issues, or timing issues, or fuel pressure/pump issues, with "CIS issues".
Buy the nicest version you can, and I don't think you'll regret it.
Cory M 06-28-2019 11:59 AM
I think most of the horror stories are from old worn out cars and the "black box" nature of fuel injection in general. If you are making constant adjustments something is wrong and the system needs a proper diagnosis.
garment 06-28-2019 12:04 PM
I've owned an '83SC for 7 years. It's been a blast, and once I learned how to check fuel pressures AND made the WUR adjustable, no problems. I'm *this close* to putting it up for sale, not b/c I don't love it (I do) but changes in my job make it so when I do drive it, I can't take a call in the car, which limits my driving/enjoyment time. Bigger problem for you may be: do you have space to work on the vehicle? I am lucky to have ample garage space (no way would I leave it out in the elements).
http://forums.pelicanparts.com/uploa...1561752097.jpg
blucille 06-28-2019 12:36 PM
I'm a firm believer that the SC was the best balance between easy to work on, lightweight-ish, bullet-proof, enough creature and safety features....best of the best.
I've owned a lot of them....I don't really like the heavy, bloated feeling of the later cars, especially the G50 equipped cars....
Don't get me wrong, my '72 is the car that lights the fire in me, but the '78-79 cars are the ones you can use the most, get the most enjoyment out of and without too much risk.
I've had a large number of cars with the 78-79, Big port, CIS motors, they are pure joy. The CIS has never been an issue in the 200k miles I've racked up on the various cars so equipped. not once. cross-country journeys, road rallies, track days....ZERO problems. Very simple system overall, with minimal electronics, and since so many other cars used CIS back in the day, there are plenty of spare parts around, and plenty of mechanics who know how to work on these cars.
ksluna 06-28-2019 12:47 PM
Thanks for all the info guys...
I think I will consider SCs or at least not be so scared of CIS.
Craig_D -- if you do a search on this forum or rennlist I would say A LOT of people have compared these two, and generally one of the main things they will say is that the Motronic > CIS.
Like I said, I don't care about the differences in performance or the 915 vs G50 debate. I just want a fun car that I can do the basics on and will start up every time (I do plan on driving it often, but not as a DD). What I'm expecting out of this car is to learn how to do most of the work myself, but of course the more complicated things I wouldn't have time or the skills for so I would want to take it to a shop. I just don't want to buy a CIS car and always be "tinkering"
I suppose I had a bad experience with a carbed motorcycle, and I know it's not the same thing as CIS, but the worst feeling in the world was trying to start your bike on a beautiful day and it won't start! I would hate for it to happen in my 911.
On another note, this car is interesting - http://forums.pelicanparts.com/porsche-cars-sale/1033160-74-911-coupe.html
OldSpool87 06-28-2019 01:21 PM
I have an ‘82. No AC and back dated heat makes engine access easy. It’s a fun, reliable car. My CIS never left me stranded and she’s not a daily driver by any stretch of th imagination (sadly). Only thing that ever got me in a pickle was a alternator taking a dump at 5am on the way to an event.
Mark Salvetti 06-28-2019 01:29 PM
I think all things being equal, I would go for a 3.2 with the Motronic. But things are rarely equal, and if I found another SC that was the right color and was in better condition than a comparable 3.2, I wouldn’t hesitate to buy another.
Lately it seems that even the 3.2’s are starting to see broken head studs. To the point that I think I would also consider an SC with a recent rebuild and new studs as a better choice than a 3.2 with original head studs.
Mark
87maniac 06-28-2019 01:32 PM
I've owned a '83 SC and '87 3.2 G50.
I went throught the learning curve of how to adjust/tune CIS, and it was very reliable.
The big difference is the torque/power of the 3.2.
3.2 Carrera is more fun to drive.
Both are ultra reliable.
boyt911sc 06-28-2019 01:43 PM
Ksluna,
The people who starts tinkering the fuel mixture on the fly are the ones giving up on CIS. The lack of knowledge and understanding is the major problem for CIS owners. You don’t tinker the fuel mixture on the fly like you do with carburetors. That is the last thing you adjust. Once it is set, do no touch it. That’s the reason they put a plug to the access hole. So people who have no experience setting up the fuel mixture would only make the problem worse.
Look for ROW SC (‘78~’83) all have the larger intake runners and no OXS/ECU. However, the US/CAN spec late SC’s have better fuel economy and reliable like the rest of the SC family. If you are not handy, find a mechanic who understands and works with CIS cars. Or start to learn how to work with your CIS car. Do not make a comparison between CIS and Motronic. They are two totally different systems and introduced in different era.
Tony
pmax 06-28-2019 01:59 PM
Compared to caveman carbs, the cap will vehemently disagree, CIS is an elegant, and basically linear, system. Get the knobs set right, and it will start.
It is ancient tech compared to modern day EFI, but amazingly Porsche still supports and sells replacement parts !
SkiVT 06-28-2019 02:31 PM
I have an 83 euro SC as Tony mentions. In Vt, you see temps ranging from the high 30’s to mid 90’s across the driving season. I installed an afr gauge mostly to see what is happening, not to constantly adjust the mixture. The main difference across the seasons is the transition time from cold running to warm running. If the engine isnt running properly, the cis components are mostly rebuildable or available new (airbox as one example). The testing for all the CIS components is very easy with assistance from this forum. Buy an SC and dont look back!!!!
SCadaddle 06-28-2019 03:00 PM
If you think the "worst" feeling in the world is a bike that won't start on a beautiful day, you're probably not ready for an SC, 3.2 Carrera or a 964 with broken head studs. It's not a matter of IF they will break, it's a matter of WHEN they will break.
roblav 06-28-2019 03:33 PM
SC's are heavy and CIS is boring. But I had multiple 1966 to 1972 cars as daily drivers. I admit to my biases.
ramonesfreak 06-28-2019 04:59 PM
I sure would love one of those but I certainly don’t have 100k+ to spend on a nice original rust free one
And since I never owned an old long hood, my SC feels very light. It’s all relative
Of course I look at these issues as someone who only paid 12k for my car when they were cheap and not in the 30k-50k range that they are today.
Compared to most cars, my SC feels like a go kart and very nimble and never boring oh and the body is galvanized
As for broken head studs. Big deal. Plan for it. Once you fix them, your unlikely to have to address the issue again. If you start with a solid rust free car with a motor in good health there really are few major issues to deal with with the SC
Any vintage car is going to have some expensive inconvenient issues that will need to be addressed. The pain of this is reduced if your long term plan is to keep the car
Coastr 06-28-2019 05:11 PM
Should you buy an SC? Yes.
Is the 3.2 motronic a better engine? Yes.
Are 3.2 cars more expensive because of the better engine? Yes.
Is the CIS finicky and requiring constant fiddling? No.
Can you fit modern Efi to an SC? Yes. For less than the price difference to a 3.2? It’s close...
HarryD 06-28-2019 05:28 PM
I have a 1973.5 911T. It is the worlds first production CIS Car. I have had it since 2002. CIS was adjusted no more than 3 times during my (current 50,000 mile) ownership.
1-When I first got it to fix a surging issue;
2-When I replaced the worn valve guides;
3-When I needed to repair a damaged cylinder.
There is an old saying about CIS:
1) The guys with working CIS systems are probably out driving their cars so they won't reply.
2) The guys that tinker with their CIS systems and have them royally screwed up will keep you running in circles with suggestions.
3) The guys that have spent a fortune on Webers or aftermarket EFI will tell you they're great to justify their expenditure to themselves.
I belong to group 1.
Downside of CIS is that it will not tolerate a hot cam and you do not get the cool induction sound of individual throttle bodies/carbs.
Upside, it that it just starts and runs.
HarryD 06-28-2019 05:31 PM
For your consideration:
K-Jetronic debuted in the 1973.5 Porsche 911T in January 1973, and was later installed into a number of Porsche, Volkswagen, Audi, BMW, Mercedes-Benz, Rolls-Royce, Bentley, Lotus, Ferrari, Nissan, Peugeot, Renault, Volvo, Saab, TVR and Ford automobiles. The final car to use K-Jetronic was the 1994 Porsche 911 Turbo 3.6.
RSBob 06-28-2019 07:11 PM
I belong to group 3 and spend every waking moment of every day trying to reconcile/justify the $ Spent versus better throttle response, mo power and that insane intake sound. After a year the $ side is losing, but tomorrow is another day... ;)
tirwin 06-28-2019 08:14 PM
I’ve owned my SC for 8 years. When I bought it I knew less than nothing. It is a totally different car since I bought it. Get in. Turn the key. Fires right up every time. So, yes, once CIS is working properly, it is a great car.
If I were in the market today, the only thing that would keep me from buying an SC is if I wanted to hot rod the motor, the SC is not a great choice. 3.2 or 3.6 is a much better starting point in that regard.
Rawknees'Turbo 06-28-2019 09:36 PM
It might be an old saying, but it is definitely no less full of hogwash than when it was new.
DonNewton 06-29-2019 06:51 AM
I've owned my '83 SC since '83, yes, original owner. I have over 135K on the clock and except for head studs popping when I came home from Desert Storm, my SC has run like a German tank. I can tell you that if the system is set correctly, you'll have no problems. The car has been from California to Rhode Island, California to Virginia and back to California. Runs perfectly.
nene 06-29-2019 07:58 AM
"And there you go, well said!"
Superman 06-29-2019 08:50 AM
I have owned and driven several German cars with CIS. Three of them were 911SCs. Others were VWs and Audis. Starting in the early 1980s and continuing to the present day. None of those cars had fuel system problems. Every single one of them started quickly and easily, and immediately ran as if they were already warmed up.
That said, I understand CIS systems are somewhat complex and can fail. If my current 1978SC needed expensive repair to the CIS system, I would consider switching to EFI or carbs.
Yes. Get thyself a G-bodied Porsche. Funnest car I have ever driven.
uwanna 06-29-2019 10:12 AM
Hey Tim,
You're not quite telling the whole story. Don't sell yourself short. When you pulled your motor you pretty much restored your whole CIS system with WUR, injectors, etc etc. You did a magnificent job and your CIS system runs like new and will probably run like a top for years to come. You did it right, like everything you do with that beautiful car!
Cheers,
Grant
G450X 06-29-2019 08:52 PM
I’ve had a high mile (160k+) ‘82 for about 10 years with only one CIS problem - a backfire blew the pop off valve off inside my air box and I had to epoxy it back in.
This thing starts immediately and runs well, only mods are SSI’s and an M&K 2/1. If I had to put money on which one of my several oddball vehicles will start, it would be my SC or ‘79 Scout...
da Vinci Dan 06-30-2019 04:31 AM
Ksluna, you and I are similar in our mechanical background, skill set, and use of our cars. The most important factor in the enjoyment of my 911 ownership is access to a reliable Porsche specialist. After 12 years of 911 ownership, I now have two whom I could text anytime. My most recent purchase has been a completely mechanically refreshed ‘88, done by the prior owner. For me, this is the best way to go.
I have only owned ‘84 or new models. Even with these “more reliable” models, I have had multiple issues with engine management - all very minor. However, a no-start or stumbling situation can be very challenging and frustrating for a novice to handle.
You are buying your car for fun. Get one that has been well maintained, even if it has higher miles. As stated prior, headstuds and trans issues are much more expensive and problematic. Rust, suspension, exhaust, interior bits and pieces... the list goes on. IF it runs well, has been cared for, and is in your price range, go for it.
Make friends with your specialists.
