New-ish 911SC Targa Owner
pampadori's Avatar
keep heat levers up or down to keep mice out
So when the heat levers are down (heat off) the gates are open under the car by the rear wheels. If they are up (heat on) then they are closed off to the outside, correct?
Is that the path that most mice will take to get under the fan shroud and nest on top of your cylinders? Or do they enter thru the alternator fan instead?
Surely someone has spoken to a mouse and asked it how it got there?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 11-12-2019, 04:48 AM
I haven't had any discussions lately with mice but you want to leave your heat levers up so the flaps are close under the car.
A few years ago I took my car out for a spirited ride in the spring. Under hard acceleration a boat load of acorns came flying out of my heat ducts onto my feet.
Lou
Old 11-12-2019, 04:54 AM
You spend an hour trying to figure out how to keep mice out, they spend their entire life figuring out how to get in.
Old 11-12-2019, 07:22 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
So the deck is stacked against us....
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 11-12-2019, 08:05 AM
mothballs under the car
1979 SC
1986 Carrera 3.6 L+
Old 11-12-2019, 09:02 AM
Slippery Slope Expert
Steam Driver's Avatar
I don’t think it really matters. The persistent little beggars are going to find a way in regardless of anything you (we) can do,
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 11-12-2019, 09:10 AM
If you leave the heater levers up, true the mice can't come in through the flapper valve, but now can prance down the piping from the engine. It's a clean shot.
To quote Bill Murray, "to catch a gopher, you have to learn how to think like a gopher."
Old 11-12-2019, 09:12 AM
I lift levers up per others above, and as well stick one of my dog's toys in the exhaust pipe. I place Irish Spring soap bars all around under the car (as suggested by others). I can't say that the soap works - in fact, I've seen signs of mice having gnawed the bars - but I've had no issues of late with rodents after many multi-month layovers. I've experienced mice in my heat exchangers after winter storage - cooked mice don't smell very pleasant...
Jason
'79 911SC Targa
Old 11-12-2019, 09:50 AM
cycling has-been
bkreigsr's Avatar
I've been under the assumption that if I want heat, I pull the lever up thereby opening the flaps to the heat exchanger surrounds.
Lever all the way down, flap is closed to the forced hot air - no?
Bill K
Old 11-12-2019, 10:19 AM
AutoBahned
RWebb's Avatar
fill a garden sprayer with oil of peppermint and spray it all over below the car
Old 11-12-2019, 10:43 AM
They also come threw the steering rack and get into the trunk. From there they go back down your brake pedal and clutch mechanism. So if they want in they will find a way.
Old 11-12-2019, 10:47 AM
Still here
pmax's Avatar
Haven't had any discussions with them but I believe removing the CAT does not help !
Old 11-12-2019, 11:48 AM
Bill K
This is correct. When the levers are down, the hot air is directed out of the open flapper valve. When left in this position the flapper allows ingress of rodents.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 11-12-2019, 01:37 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Bill K
Bill, it's the wording that might be confusing you. When the handles are down, the valves are open and the forced hot air is directed out into the open air through the valves. When you pull the levers up, you are closing the valve and allowing the heat to make its way forward inside the car.
Marc
Old 11-12-2019, 03:12 PM
The 9 Store
Adult mice can squeeze through a hole the size of s dime.
Old 11-12-2019, 03:43 PM
Banned but not out, yet..
RSBob's Avatar
Levers up
Hood up
Frunk up and perlon stored some where in the garage
Glove box door up/open
Arm rest covers/doors up
And forget the car cover unless it is clear plastic
They don’t like light so the more you provide, the less likely they will start a nest.
Old 11-12-2019, 04:53 PM
Been here a while
I leave a local talk radio station playing 24/7, haven’t seen any critters since.
looking for 1972 911t motor XR584, S/N 6121622
Old 11-12-2019, 04:59 PM
This. This is good.
Old 11-12-2019, 05:23 PM
dyusem's Avatar
Originally Posted by RSBob View Post
Levers up
Hood up
^This is the key. I leave the garage lights on and have no problems...
Old 11-12-2019, 05:28 PM
rokemester's Avatar
I heard a while back to scatter dryer sheets throughout the interior, frunk, engine bay. Just don’t forget to remove them in the Spring. Ask me how I know!!
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 11-12-2019, 08:09 PM
