JTL JTL is offline
JTL's Avatar
Porsche Crest Inside Door Handle Pull Rod
The PS door handle pull rod broke. I ordered another one, an original Porsche part, from PP but the rod is too long even when adjusted all the way in. It does work but the handle doesn't sit flush when not pulled.
I haven't tried any used parts suppliers yet; guess that's next. Any other ideas? Thanks!
Cheers, Jt
-84 911 targa
Old 06-28-2019, 05:06 AM
New-ish 911SC Targa Owner
pampadori's Avatar
is the targa a different part number than the coupes? I know some items in the doors are different.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 06-28-2019, 06:44 AM
JTL JTL is offline
JTL's Avatar
Arrow
The PP catalog only has the one option, part # 993-531-091-02-M100. Price is about $50
Interestingly the part # is a 993-xxx. There was 1 customer review stating the same thing I experienced. It would seem this part doesn't fit older 911's.
Cheers, Jt
-84 911 targa
Old 06-28-2019, 07:01 AM
pampadori's Avatar
inside door handle dead!
looks like you need multiple parts to make it work on older cars.
Old 06-28-2019, 07:19 AM
JTL JTL is offline
JTL's Avatar
Thanks for the link but I did already find that thread. After the PS rod broke I went ahead and replaced all the bowden cables and plastic bushings as it looked like they were original/old.
All the other parts work a-ok except that rod. I was able to reuse the DS rod. With the new parts and slight adjustments the door pops open almost without effort - sweet.
Cheers, Jt
-84 911 targa
Old 06-28-2019, 08:10 AM
I to looks to me that the correct part for an 84 (Targa, Coupe, Cab are all the same) is 911 531 091 00. Pelican shows this as a special order part. for 85 on the last to digits changed to 01 which supersedes to 993 531 091 02.
Looks like you need the earlier 00 part, or you need to swap to the later style parts for Bowden cable and relay lever.
84 to 85 SN 21226
911 531 091 00 Pull Rod
911 531 509 00 (L) Bowden Cable
911 531 510 00 (R) Bowden Cable
911 531 083 00 (L, R) Relay Lever
85 SN 21226+
911 531 091 01 superseded to 993 531 091 02 Pull Rod
911 531 509 01 (L, R) Bowden Cable
993 531 083 00 (L) Relay Lever
993 531 084 00 (R) Relay Lever
Old 06-28-2019, 10:27 AM
JTL JTL is offline
JTL's Avatar
Hey 76FJ55,
Many thanks for that info!
Now I can get the correct part. $9.50 sounds way more reasonable as well Might be a bit of a wait for a special order part.
Cheers, Jt
-84 911 targa
Old 06-28-2019, 10:36 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Cut the threaded end a bit. Assuming the two ends touch each other before you run out of thread.
Chris
Old 06-28-2019, 02:34 PM
