one of gods prototypes
bell's Avatar
rear caliper rebuild question......dust boots
what's the trick to get the rear caliper piston dust boots to clip on?
the calipers were blasted and cleaned and there are no obstructions around where they should seat, the metal clips inside the boot are intact and not twisted, i just can't get them to seat in.
any tips would be greatly appreciated since i'm in the middle of this right now
Brought to you by Carl's Jr.
Old 03-23-2003, 11:08 AM
autobonrun's Avatar
I just finished mine last week. The lip of the dust boot should snap in place around the piston. After pressing the piston back into the cylinder, there should be a groove remaining around the outside where the snap ring will fit. Once on, I gently pressed the ring further in place using a small screwdriver, being careful not to let it slip and rip the boot.
Old 03-23-2003, 11:13 AM
bell's Avatar
that did the trick........i didn't want to take the chance on riping the boots, but this worked fine thanks
Old 03-23-2003, 12:56 PM
