Mystery Wires
Posted earlier but experienced photo upload issues.
Might anyone know what these wires go to on a 69-73 911 in the trunk? Photos #1 and #2 are a group of wires coming off the harness from up near the gauges. #3 is a single light blue male terminal that separates from the cluster that connects to the heater blower. I appreciate any help you all can offer. ![]() ![]()
ROW '78 911 Targa
Single Blue wire is for the Webasto heater option.
Group of wires: (assuming they are coming from the through body harness) Black- rear defroster White/black- rear defroster 2nd stage White/green- rear driver side fog lamp (European option) Yellow? Or what colors? Not sure without knowing color or if it has a stripe. Could be from hand brake area as a quick guess if yellow/brown I don’t recall seeing that color wire grouped with the others. Maybe someone relocated it? If plain yellow it could run to the starter solenoid. Need to do some tracing. A continuity test to the rear 14 pin connector, pin 1 would confirm. Green is a jumper used on the rear defroster switch. Hope that helps
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 06-24-2019 at 11:15 PM.. |
Dennis, your knowledge is amazing!
Robert ----------------------------------------- "A man must consider what a rich realm he abdicates when he becomes a conformist." ~ Ralph Waldo Emerson ~ (thanks to Pat Keefe) |
The Yellow is a brown and yellow stripe. If I can ask you another... There is a black with white dots and a green stripe exiting the harness by itself right up near the back of the gauges. And the the last one was extra double black switched power wire without an obvious home. ![]()
ROW '78 911 Targa
Double black wire in one connector and really long should be clock.
Black/green/white is usually for the hazards. I’ll look at my stuff at home tonight to confirm the black/green/white.
Regarding the black and green(white dots) wire, my hazards are currently working so I'm not sure what this one is for... possible oil slick/bullet deflector? Thank you for your continued help. It's very much appreciated. |
ROW '78 911 Targa
Double black also runs to rear defogger switch and glove box lamp.
If male connector it is for dome lamps. I’m at work so just going from memory on these. Black/green /white coming out from a relay base? Have to check where it goes tonight.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 06-25-2019 at 10:22 AM.. |
The black/green/white exits the harness by itself right behind a relay up near the gauges. |
Sent from my BBB100-1 using Tapatalk
1988 911 Coupe Granite Green "Frogger" 1966 912R Coupe Stone Grey outlaw -"'Tilda" 1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter" 1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio) 1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001 |
Thank you for the heads up.
