RichPugh's Avatar
What to do regarding rusty flywheel? 3.0 SC / 914-6 Swap
I'm starting an SC swap into my 914... I'm gonna grab the Kennedy adapter ring for 9-bolt flywheels and a 225mm clutch kit to keep my 901 trans but I didnt think I should simply ignore this rusted flywheel. It all seems to be superficial surface rust so... let it soak in a rust dissolver solution or de-ruster? Brake-clean and some steel wool? Scotch-brite and CLR? What do you think...
Edit: I do plan to take it off to inspect and most likely replace the RMS.
'73 914 3.0 6 Swap • — '96 993 Carrera 4 • Iris Blue • Supercharged • SOLD. -- '05 997 Carrera S • Black Launch Edition • SOLD. -- '97 993 C4S • Black • Bone Stock • SOLD — '95 RoW 993 Carrera 4 • Aventurine Green • Non-Sunroof • Cloth Interior — Wrecked + SOLD
Old 09-05-2017, 12:17 PM
Install the clutch, it'll clean where it runs
Old 09-05-2017, 12:20 PM
New-ish 911SC Targa Owner
pampadori's Avatar
can you drop it off at a machine shop and have them media blast it and then chuck it on the lathe to ensure a flat surface?
Without knowing more than I do, thats what I'd do if it were me.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 09-05-2017, 12:25 PM
RichPugh's Avatar
That's what I initially thought but figured I'd ask. Thanks.
Old 09-05-2017, 12:27 PM
RichPugh's Avatar
Yeah I probably can. I guess better safe than sorry but I don't think anything is questionable with it's true-ness.
Old 09-05-2017, 12:29 PM
GaryR's Avatar
Send a message via ICQ to GaryR
If it's coming off I would sandblast it if it was mine..
Gary R.
Old 09-05-2017, 12:32 PM
I think if you put the 3L in the 914 you will need to change the flywheel anyway.
Old 09-05-2017, 02:15 PM
RichPugh's Avatar
Nah, the stock 225mm 9-bolt flywheel stays on the 3.0 engine and Kennedy (or Patrick MS) offers an adapter ring "kit" to mate a 228mm clutch which works with the stock 901 trans clutch operation :thumbsup:
Old 09-06-2017, 10:48 AM
Slippery Slope Expert
Steam Driver's Avatar
I don't think sand/media blasting is a good idea as it would leave a much rougher surface than normal and maybe make it "grabby." I would Scotchbrite the devil out of it then reinstall and let normal usage do the rest.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 09-06-2017, 11:14 AM
Have it resurfaced at a machine shop.
Old 09-06-2017, 12:18 PM
85911's Avatar
+1. In the old days, when we changed clutches we had our flywheels turned to remove grooving from worn out driven (clutch) plates and to make sure they were flat and true from warping due to heat.
Is the ring gear pressed on? I easily installed a new one on a different car by heating the ring and putting the flywheel in the freezer. It fell in place.
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold
Old 09-06-2017, 04:04 PM
Jeff NJ's Avatar
Blanchard grinding is the best option, IMO.
1988 930 Venetian Blue
Old 09-06-2017, 04:40 PM
RichPugh's Avatar
After speaking to several other people, I think the move it to either lightly scotchbrite it (if there is no reason to believe the flywheel is pitted or warped) OR just have it resurfaced at a local machine shop. I think the 2nd option is probably not cost prohibitive so I'll probably just do that. Thanks everyone
One more pic for project posterity, lol
Old 09-06-2017, 04:59 PM
Great photo panning with the car. Beautiful car love the color and the red decal.
Old 09-07-2017, 05:27 AM
RichPugh's Avatar
Thank you! The PORSCHE letters are Orange
Old 09-07-2017, 10:24 AM
You're to big to be driving that car you should sell it to me!
Old 09-07-2017, 11:52 AM
RichPugh's Avatar
LOL... No.
Also, I took the flywheel to a local machine shop and couldn't be happier.
Old 07-08-2019, 08:20 AM
ChieftanMews's Avatar
Wow that cleaned up nicely!
1980 911 SC - Project
Old 07-08-2019, 09:50 AM
