Harlan Chinn's Avatar
Porsche Crest Fire Extinguisher Bracket in a 911
Where are you mounting your fire extinguisher in your 911's? This is a street car, sans harness bar or cage. I understand Brey Krause does a bracket, where does it go and is this a good one?
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 03-23-2003, 08:57 PM
Don Plumley's Avatar
The BK bracket installs on the seat rail, just in front of the seat. Typically the pass seat. Here's my low-cost solution.
Don Plumley
M235i
Old 03-23-2003, 09:10 PM
pjv911's Avatar
Send a message via AIM to pjv911
I have the Brey Krause mount and love it. It does not get in the passengers way unless there less than 5 foot tall. It looks pretty neat as well. It is nice to keep it this close.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 03-23-2003, 09:44 PM
me to
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-24-2003, 02:37 AM
Irrationally exuberant
ChrisBennet's Avatar
The BK brackets come in at least a couple of flavors. Some move with the seat and some restrict the seats movement. I recommend getting an extinguisher holder with 2 straps. I don't see them listed by our host but OG Racings has the 2 strap flavor. For DE events you will need a holder with at least one strap. The one in pjv911's picture appears to have no straps at all and wouldn't pass tech in the regions I drive with.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-24-2003, 05:03 AM
pjv911's Avatar
Nope no straps. I could install one easily but its optional . Car is used for street only.
Kurt Williams
Old 03-24-2003, 05:37 AM
Hald's Avatar
This outfit carries the extinguisher mounts that move with the seat.
http://stable-energies.com/exting/index.htm
regards,
Mark
'77 Carrera 3.0
http://members.rennlist.com/hald
Old 03-24-2003, 05:48 AM
Here are a couple of pictures from OG Racing's web site.
Single strap holder:
Double strap holder:
I used to have a BK bracket in my 911. Now I have the extringuisher bolted behind the passenger seat. It's within arms reach, I can move the seat back and forth again and it isn't snagging passenger's ankles. I bolted it to the vertical wall just in front of the rear passenger seat. It makes that rear seat unusable but I have a roll bar so no one is going to ride back there anyway. If you decide to bolt the extinguisher behind the seats, do not bolt it to the cover on the "hump" back there.
For my 944 I made a bracket out of 1/8" aluminum and bolted it under the seat tracks.
-Chris
Old 03-24-2003, 05:49 AM
