bigchillcar's Avatar
Question what fails in oil pressure sender?
mine needs replacing..i guess. part of me wants to remove the part, 'bang on it' and stick it back in and see if it works. what's the principle with it? how does it fail? is this worth a try? after all the darned things cost over $70!
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 08-26-2005, 10:25 AM
randywebb's Avatar
my bet is that the metal accordian fails (turns into a tuba or something...)
it is not worth your while... trust me - if you still have that desire to bang on things, you can alleviate it by going to grad. school in one of the hard sciences
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 08-26-2005, 06:38 PM
Wider is Better
wholberg's Avatar
I could not find a picture of a Porsche unit, but most oil pressure sending units have a spring that compresses as oil pressure increases, and the movement inside the unit is translated electronically to gauge movement. Pressure sending units fail when the spring eventually collapses or breaks due to metal fatigue, so when they break, they are broke for good. Just replace it.
Wider is Better
Old 08-26-2005, 08:20 PM
mine is sort of intermittent..it's accurate only now after the oil has heated..when cold it just pegs out. still replace or can i beat on it? please..?
ryan
Old 08-26-2005, 11:25 PM
randywebb's Avatar
beat it
Old 08-27-2005, 12:06 AM
fwiw.. old hard info is that art classes had more action for banging than the hard sciences.
and senders get beat over time.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-27-2005, 01:09 AM
ohhh, okay. damn..i really wanted to beat it..
ryan
Old 08-27-2005, 06:38 AM
Irrationally exuberant
ChrisBennet's Avatar
The oil pressure gauge will peg when the sender is disconnected right?
Sounds like the potentiomer "wiper" is making intermittent contact with the track inside the sender. Replacethe sender. I've got a cut open one I saved. If someone really wants a picture I'll dig it out and take one.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-27-2005, 08:18 AM
randywebb's Avatar
A pic would be a public benefit, Chris!
Ryan - feel free to beat it - even tho that won't make it work again...
Old 08-27-2005, 01:14 PM
the pics may not be an exact bosch design.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-27-2005, 02:10 PM
thanks for the diagram, ron..sounds like my diaphragm is weak..at start the higher pressure must be expanding it to full resistance and as the temp inceases and pressure decreases, it must start shrinking back and starting to indicate accurately..at least for now until it finally gives. new sender it is..and i promise when i get the old one out I WILL BEAT IT!
ryan
Old 08-27-2005, 03:00 PM
randywebb's Avatar
take the can off w/ a nibbler or Demel cutoff tool or shears
post a pic of the internals
then crush the whole thing with a sledge hammer; toss into recycle bin and have a beer
Old 08-27-2005, 03:59 PM
ryan
If the dial is pegging sometimes, I don't think the diaphram is at fault. Pegging the dial is the symptom I usually associate with a disconnected (911) sensor. My theory is that the electrical part of the sender (the potentiomer) is the culprit.
-Chris
Old 08-27-2005, 05:03 PM
Old 09-02-2005, 02:05 PM
chris,
thanks for the pic! is that beneath the top of the sender where the wire enters? i'm still peggin' when pressure is high as in cool oil..working normally once pressure drops and oil warms. you can predict everytime you drive approximately when the needles going to fall from the top and begin working accurately.
ryan
Old 09-02-2005, 03:49 PM
chris,
ryan
Yes, that red wire would go to the spade connector on the top of the unit. If you remove the sender (easier said than done) you can "test" it using your air compressor set at different pressures.
I'm as frugal as they get but I don't think you can fix one of these senders.
Of course just saying that is going make you try all the harder isn't it?
-Chris
Old 09-02-2005, 05:52 PM
boy, it's tempting..lol. no, i think it's time to spend the $70-odd bucks. just the other day i ordered a new turn signal relay..and you know what? as soon as the part shipped, my old relay began working after i found a loose turn signal bulb in its socket..naturally. i just know this baby is waiting to start working as soon as i order a replacement too!
ryan
Old 09-02-2005, 06:32 PM
randywebb's Avatar
no no - don't spend $70! never do that when you can waste months out of your life fiddling with it first...
Old 09-02-2005, 09:00 PM
randallll..do i detect a note of sarcasm..?? hmmmmmmmmmmm?
ryan
Old 09-02-2005, 10:24 PM
rw7810's Avatar
I’m having the exact same issue on my 2.2 liter, any updates?
Robert Williams
70' 911T
Old 09-20-2020, 03:33 PM
