Limbo
Slider79SC's Avatar
naca ducts?
Anyone know where I can find naca ducts that are made out of metal? All I can seem to find are fiberglass or carbon????
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 12-22-2011, 09:04 AM
Porchcar guy's Avatar
Type in your computer search engine ...metal NACA duct.... here is one of many
BUTLERBUILT
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 12-22-2011, 09:23 AM
Limbo
Slider79SC's Avatar
I checked their site, all of their products are plastic, no metal. I searched for an hour and never came up with anything....
Old 12-22-2011, 09:27 AM
5:04's Avatar
I just searched for 14 seconds and found it.
that911.tumblr.com
Old 12-22-2011, 09:35 AM
Scroll down and look at what 5:04 said
15 year PCA member
Old 12-22-2011, 09:37 AM
Limbo
Slider79SC's Avatar
Thanks but those are aluminum and I need steel. I need to weld them into existing steel. I just called them and the don't carry them in steel.
Old 12-22-2011, 10:21 AM
There are a number DIY sites to make your own if steel is not available or talk to a metalworking shop about making some one offs..
15 year PCA member
Old 12-22-2011, 10:23 AM
Diss Member
Quicksilver's Avatar
It you are up for welding one into a car then you easily have the skills to make your own ducts. They are easy to form out of flat sheet and they just need to be welded with the sides 90° to the bottom. If I was making one I would make a wooden form on a bandsaw and then just clamp the side metal to the form and trim it to the contour. Then tack the bottom to it and trim to size. A finish bead and you are done and you just need to weld it to the car.
If it was me I would just is 3M VHB tape and bond a preformed duct to the underside of the skin. VHB is structural so it will never come off and it is as permanent as welding.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-22-2011, 11:19 AM
Where are you looking to place these on the car ? Is it a racing application ?
15 year PCA member
Old 12-22-2011, 11:21 AM
Max Sluiter
Flieger's Avatar
If you make your own (or probably even buy one) the profile is likely not going to be 'correct'. They were engineered for high-speed airplanes as a way to get air without disturbing the boundary layer much and with as little drag as possible. The shape would vary based on Reynold's number I would venture.
Old 12-22-2011, 11:28 AM
