nico55
3.0 RSR engine
Hi,
hope you guys can give me some feedback on a rsr engine that I can buy, do those numbers exist and is there a car that can be coupled to this engine? I am from Belgium and the engine is located in Germany. Thanks in advance and regards, Nico Last edited by nico55; 07-13-2019 at 01:42 AM.. |
The 9 Store
People always say it's too far to travel, send money based on some pics and promises and then are upset when the deal goes south. If it's worth buying, it's worth making the trip to verify it exists and bringing along someone who knows what they are looking at.
All used parts sold as is. |
nico55
This is a question to verify the numbers, if they are correct I will do the trip, no problem.
I am not up on the RSR's so do not know what year this is supposed to be, but if you have not done so yet, you may want to post over on Early911sregistry. They seem to have more knowledge on these early cars. Nominally they are interested thru 1973.
keep up informed on how it turns out.
Who, What, When, Where, Why and How. |
here is some info for you...
http://www.911specs.com/VIN73s911.htm
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Rsr engine
I have repaired a number of this engine type and there are a number of things that are not correct here.A few more photos and I can point you in the right direction.Thanks Fred
hi faapgar..do you think the 68 is strange or?
Rsr engine
Ok,first glance.If the motor is more than $50,000 run.Intake valve covers,wire set,headers,fiberglass shroud,obviously engine number,Slide Valve injection is a repop.Chain housing covers should have an oil line to the center and they are pure magnesium.Fan may be a correct size but the color is too dark to be original.German repop.More pics please.Fred
nico55
Hi Guys, thanks for the feedback! The production number seems very high to me?
I could do a partial trade so it could be interesting, but at least the number should be ok... Thanks again |
3.0 rsr
Number is bogus I have to say the best fake font I have seen to this day.To pull it off they should have sprayed muriatic acid on about 3 times with water and repeated until color was correct.Ciao
It's a 914 ...
A closeup of the injection pump will be telling also, if that hasn’t been mentioned.
injection pump
Pump would have a steady rod with a rubber bushing from the top of the pump to over by the O.P. Switch.There are many nuances with these motors.Maybe Steve Gold will post a pic of his RSR motor instead of you asking to send you one.Rebuilt by Brumos tech.Show us the pic for $150,000.Everyone wants a pic even if they know what it looks like.
nico55
@faabgar: I am in contact with Steve Goldin, thank you for the feedback on his engine. Regards, Nico
MFI pump looks to be a 70 - 71 single solenoid E or S standard pump not RSR.
Mark Jung Bend, OR MFI Werks.com |
