Porsche 911 Rear Wiper Switch to Fan Motor
I have upgraded to the Elephant Racing 911 front mounted oil cooler. In the book 101 Projects for your Porsche 911 by Wayne Dempsey it is suggested that you use a rear wiper switch to start and stop the fan motor. My question is how do I wire the 4-pronged rear wiper switch that I just purchased from pelican parts. My car does not have the rear window wiper. Thanks.
Old 05-03-2017, 04:19 PM
Administrator
Luccia at Pelican Parts's Avatar
Bump! Post was in moderation, so want to get your question back to the front page. Any Pelicanites have some input for him?
Old 05-04-2017, 08:07 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Temp sensor.
If your new oil cooler has a bung, install the factory temp sensor
in conjunction with a relay and a fuse.
pm me as needed.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-04-2017, 08:22 AM
Burnin' Rubber
Koizumi's Avatar
I’m wondering if you’ve figured this out.
Old 07-10-2019, 12:40 PM
this kinda helps a bit Question on rear wiper switch 91161332101
Seems the key is to bench test it with a test light to determine which connectors toggle on/off with the switch and then use these connectors to trigger a relay instead of directly handling the current going to the motor.
edit -- here's another -- Rear wiper help Needed
Sounds like terminals 53 and 53a are the ones to try first, as that looks to put the switch between the fused power and the motor
Old 07-10-2019, 12:55 PM
I used this link to wire my switch.
oil cooler fan t'stat and switch installation
Tapped into the grey wire in the trunk, ran a wire to the switch. Ran another wire from the switch to a bolt on a trunk bolt hinge. Flip the the switch up fan acts as normal, flip the switch down and the fan comes on. I think I used the top two terminals on the switch.
87 Venetian Blue 3.4
Old 07-10-2019, 02:17 PM
El Duderino
tirwin's Avatar
My car has an oil cooler fan wired to the rear wiper switch by a previous owner. My question is, why not either wire it to run constantly or just leave it on all the time? It’s much easier to prevent high oil temps by running the fan BEFORE you really need it rather than turning it’s on AFTER you have high oil temps.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 07-10-2019, 02:22 PM
With my setup you could flip the switch so it is on all the time. But I rather not have the fan running all the time. Wear and tear on the fan I guess, in the winter there is no point in having the fan on at all. I rarely get above 210 in the winter. In the summer I switch it on when it gets above 210ish boil out the water in the oil (high humidity in Houston) and it takes 5min or so and it drops back down to 190ish. As long as I am moving it stays in the 210 range, but if I get caught in traffic and the middle of the summer 2 things happen. 1. I start baking 2. the car temps start to climb. So if that happens I flip the switch on if I encounter traffic and keep the temps around 210 for peace of mind. Just the way I do it, seems to work for me.
Old 07-10-2019, 02:28 PM
Burnin' Rubber
Koizumi's Avatar
You guys are awesome, thanks!
Old 07-10-2019, 05:54 PM
El Duderino
tirwin's Avatar
I see your point but then wouldn’t it make sense to rig a thermostatic switch to come on at say 210? I just prefer the automatic approach. One less thing to think about... but it’s probably splitting hairs.
Old 07-10-2019, 07:08 PM
I also used ianc's thread as a reference on installing a rear wiper switch for my oil cooler fan-Thanks ianc!
Left the stock thermostat as I was lazy to replace it with the BMW part.
Old 07-10-2019, 08:47 PM
Yup,
Here is what I used.
210f-On
197f-Off
Gerry
1986 911 Targa.
Only in L.A.:
Old 07-10-2019, 09:49 PM
El Duderino
tirwin's Avatar
Awesome, Gerry! I’m adding that to my to-do list.
Do you have a source for the thermostatic switch?
Old 07-11-2019, 06:25 AM
Switch.
Nason is the name of the company.
https://www.nasonptc.com/
Just call them & tell them what you need.
As mentioned I used:
197f-OFF
210f-ON
You will also have to add a relay at the fuse panel.
Gerry
1986 911 Targa.
Only in L.A.:
Old 07-11-2019, 08:15 AM
197f-ON
210f-OFF
Gerry
Gerry -- think you have it backward on the above -- 210 ON and 197 OFF, right?
Old 07-11-2019, 09:02 AM
oil.
Spot on!!!!
Post corrected.
Thank you.
Gerry
1986 911 Targa.
Only in L.A.:
Old 07-11-2019, 06:15 PM
