Red face Anyone lost a dipstick down the filler neck?
I have an 81 930 and lost the dipstick (I know...I'm the dipstick). I think it might have gone down the filler neck. I can't see it down there, but I can't find it anywhere else!
Has this happened to you? What did you do?
Old 09-13-2020, 04:46 PM
Search with a flex magnet...
Bruce
Old 09-13-2020, 04:49 PM
Hate to admit it, but I also dropped mine down the filler neck once...
I got lucky and fished it out with a piece of welding wire with the end bent into a hook.
Wise advice is to forget it's down there and buy a new dipstick. Won't hurt anything in the oil tank.
Edited: removed incorrect info...
Old 09-13-2020, 05:21 PM
Bill Douglas's Avatar
Yep...
The first day I got the porsche.
Powerhaus man, Jon Pottinger, was down at the docks picking up some 911s and hooked it out for me with a bit of bent wire.
Old 09-13-2020, 05:24 PM
Me too. I think you have to drop one down there don’t you? I heard it’s like breaking a champagne bottle on a ships hull before its maiden voyage
Old 09-13-2020, 05:36 PM
HarryD's Avatar
It is said that you can determine the number of owners of your 911 by removing and counting the number of dipsticks in the tank.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-13-2020, 10:21 PM
Oil dip stick.....
I got lucky and fished it out with a piece of welding wire with the end bent into a hook. I believe the dipsticks are stainless, fishing with a magnet won't work.
Solamar,
When you get a chance, test your oil dip stick with a magnet. You will be surprised. You probably have not tested one before because a 911 oil dip stick could be picked up by a magnet. I had used magnets to retrieve and picked up stray oil dip sticks a few times. BTW, my oil dip sticks are not made from stainless steel.
If you could not retrieve the stray oil dip stick through the oil fill tube, remove the oil tank level sender unit and use the access hole to pick up the dip stick.
Tony
Old 09-14-2020, 03:03 AM
My other ride is a C-130J
RNajarian's Avatar
Would an errant dip stick inside the oil tank potentially interfere with the oil level sender unit?
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 09-14-2020, 04:39 AM
Behind the Sun
Drain the oil
Get a coat hanger. Go fishing or "Sticking" through the drain
Not hard at all
Old 09-14-2020, 06:29 AM
Originally Posted by boyt911sc View Post
Solamar,
Tony
What a waste of my 'once per year' Mulligan
Sure enough, my dipstick IS magnetic. I was positive that I had checked it before...
1978 SC Targa
Old 09-14-2020, 09:03 AM
7783911's Avatar
easier question is who hasnt :-)
Old 09-14-2020, 09:13 AM
Red Line Service
Marc Bixen's Avatar
Don't worry about it, just get another. I once pulled 4 dipsticks out of one oil tank. As for a replacement, check the part number on your level sender, there was an update 80-81 and there are 2 different dipsticks. The .01 sender uses the .00 dipstick, the .02 sender uses the .01 dipstick.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 09-14-2020, 10:01 AM
HarryD's Avatar
For the metal geeks here:
Austenitic stainless steels (the 300 series) are non-magnetic.
Ferritic stainless steels (typically the 400 series) ARE magnetic.
Harry
2020 MB E350 4Matic
Old 09-14-2020, 10:09 AM
Nope, never done it. I always find the little tube it goes in before I shove it down tight. I just try to move the handle back and forth a bit and it it will not move, it is in the tube.
Old 09-14-2020, 10:15 AM
proporsche's Avatar
I`m as Glen, never dropped one in ........but you never know ,i might do it next time i check the oil;-)))))))))))))))
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-14-2020, 10:22 AM
shoooo32's Avatar
My targa came with three dipsticks; two in the bottom of the tank and one in the correct location. They're non-magnetic so bent wire is the best way to fish them out.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 09-14-2020, 10:47 AM
