Any LA wreckers that have 80s parts?
Other than LA Dismantlers, are there any yards that have mid 80s parts cars, in SoCal?
Need a wire loom for an 86. From ignition switch to cowl and light switch. Separate loom from the other stuff under there. THX.
206 637 4071
Old 07-05-2019, 01:20 PM
Diss Member
Quicksilver's Avatar
Einmalig in HB always seemed to have a good quantity of aircooled stuff but I haven't been there in 3 years. (They seem to want top dollar too, but I am cheap...)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-05-2019, 01:30 PM
Been here a while
GR and sons in Laguna Beach....I've bought some stuff from them, prices are negotiable....
looking for 1972 911t motor XR584, S/N 6121622
Old 07-05-2019, 01:36 PM
proporsche's Avatar
John try ..these guys @. mattman@retroautomotiveproducts.com
he has plenty of stuff..east coast thou...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-05-2019, 01:39 PM
Doesn’t Tim on here Specialise in making new 80s harnesses ?
Old 07-05-2019, 04:28 PM
Einmalig had the harness. Thanks!
206 637 4071
Old 07-05-2019, 05:59 PM
It seems the CHT sensor for 3.2 is about impossible to find . My shop had to go to Der Fatherland!
Old 07-05-2019, 09:39 PM
Turbonut
Raceboy's Avatar
With little modification VW bug CHT sensor fits (has the same M10x1 thread but single wire and needs ground wire + male JPT 2 pin connector to be soldered). There are several ones but there is correct one with correct 2kOhm curve.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 07-06-2019, 12:44 AM
proporsche's Avatar
Nick ..even here in Europe is hard to locate one(except in my tool box i have 2)..But on ebay.com are plenty ,why not buy it there??
Ivan
Old 07-06-2019, 05:05 AM
parts haven
Old 07-16-2019, 03:11 PM
I posted a similar observation a few weeks back - these sensors are made from un-obtainium.
More so, than just a manufacturing shortage by Porsche and Bosch.
Makes one think there is a patent infringement tangle or maybe something in the ceramics process has gone awry with raw materials ? Tariff FUBAR ?
Always take the high road, it's far less crowded - Charlie Munger
Old 07-16-2019, 06:49 PM
Wildman Emeritus
Just ordered a used A/C fan switch from Einmalig and expect it today/tomorrow. Mike thought he had one, checked and called me back in 10 minutes.
Tried our host but they, like everybody else, offer the superceding part which is completely different and comes with no wiring diagram, necessary for me as terminal locations are different and I am an electrical idiot.
I will definitely use them again.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 07-17-2019, 04:51 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
harness.
pm sent.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-17-2019, 07:51 AM
All Bosch "fluid" temp sensors have the exact same curve - this is down to the semi-conductor technology, and isn't configurable/doesn't vary.
There's a generic Bosch sensor with a JT connector 2 pin on the device itself. Take care of the clearance issue, little flying lead with JT plug/socket each end to mate to the factory harness and you'd be good.
There are other temperature sensors, which don't use the same technology; e.g. Magneti Marrelli make one, used on Fiats and Ducati.
The MM temperature curve is different to the Bosch device, but it probably doesn't matter - 0-50C is probably close enough; my tune is getting rid of warmup compensation pretty quick by the time the CHT reaches 50C; motor just doesn't need it.
There's something like a 10-15C discrepancy between the two technologies by 100C or so - but I really think the Motronic is past caring about enrichment at that point.
So all you would need to worry about is arrangements for the electrical connector, and the mechanical clearance (most "short-reach" fluid temp sensors have 17mm of brass extending beyond the thread, unlike the 3.2 temp sensor which ends right there). Maybe a plug that screws into the cylinder head and has room for that extra length?
Most of the generic sensors will run you $20 or so new thanks to the volume they're produced in - so it's probably worth figuring out how to adapt one...
Or buy a 964 one for $100 and re-pin it to the appropriate connector.
'77 S with '78 930 power and a few other things.
Old 07-17-2019, 12:44 PM
