Tom '74 911's Avatar
Engine Compartment Electrical Connections - wire clips
Hello,
I was just prepping to drop the 3.2L in my SPEC 911 for winter maintenance and was wondering if there is an official method or tool for unhooking the electrical connectors that are held together with those little wire clips? I used a small flat blade screwdriver to pry the wire clips away, then was able to unhook the connector and then replace the clip for re-connection.
Is there some other/better way to get at those little wire clips? I tried using some circle clip pliers, but really, the screwdriver method worked best.
Thanks,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 02-09-2020, 04:57 PM
ROW '78 911 Targa
timmy2's Avatar
A lot of people suggest to rock and pull the connector off. The springs will stretch to allow it.
But, with the age and brittleness of those connectors, you are likely doing it the best way.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-09-2020, 05:00 PM
