-   -   1975 2.7 running to hot timing problem???? (http://forums.pelicanparts.com/porsche-911-technical-forum/1035268-1975-2-7-running-hot-timing-problem.html)
rickpollman 07-21-2019 10:26 AM
running hot can't seem to get the timing marks to line up without the distributor rotated all the way clockwise, if the cam timing was off would it start so easily and run correctly?? http://forums.pelicanparts.com/uploa...1563729873.jpg
http://forums.pelicanparts.com/uploa...1563729873.JPG
ClickClickBoom 07-21-2019 10:35 AM
Mine ran hot until I added a fender mounted cooler.
Flat6pac 07-21-2019 10:55 AM
You’re distributor is one cog off inside the motor.
Set Z1 on #1 cylinder
Remove nut on dist.
Lift up until the rotor is free to spin.
The rotor turns clockwise.
Reset rotor to leading edge lines with mark on edge of the distributor.
Reset the dist. You should line up with more adjustment available.
Bruce
rickpollman 07-21-2019 12:37 PM
too hot
http://forums.pelicanparts.com/uploa...1563737663.jpg
Have already rotated the drive gear and to get it timed the dizzy has to be rotated to the opposite end of the adjustment range
Flat6pac 07-21-2019 12:54 PM
Well, you went one too many teeth.
Bruce
Targalid 07-21-2019 01:04 PM
Mine ran really hot when I first got it. The timing was retarded, the fuel mixture was off, some air hoses were loose allowing cooling air to escape the proper path and I had a 5 blade fan. One of the things I did was to remove the alternator/fan and notice that the engine cooling fins were coated with oil/dirt. It took a fair amount of diesel sprayed in there to loosen the grease followed by steam cleaning to remove the loosened gunk. That dropped the temps another 20 degrees. It ran much cooler after proper timing, proper fuel mix, tightened air hoses, engine clean from above and 11 blade fan. Then I got the trombone cooler which dropped the temps some more. I seldom go over 210 these days. If you don't have a trombone cooler I have an extra.
nomore 07-21-2019 01:27 PM
What Flat6pac said. The dizzy hold down nut should be about the middle of the adjustment space.
How hot is too hot?
rickpollman 07-21-2019 02:17 PM
Installed at Z-1 top dead center
http://forums.pelicanparts.com/uploa...1563743706.jpg
this is where the dizzy needs to be for 5 degrees after z-1 @ 900 rpm
rickpollman 07-21-2019 02:33 PM
gets up to 210 and keeps heading for 250 so I shut it down this is after only running 20 minutes or less
rickpollman 07-21-2019 03:05 PM
just ran it again and after 20 minutes over 210 on the gauge but I used infrared thermometer down into oil tank and oil is 140 degrees??????
Targalid 07-21-2019 06:33 PM
Those hand held point and shoot thermometers are really helpful. You may have a mismatch between the temperature sender and the dash mounted temperature gauge, giving you a false reading.
Walter_Middie 07-21-2019 06:49 PM
Rick,
Your picture shows the vacuum line still attached. It's 5 deg ATDC with the vacuum line disconnected (and plugged) at idle, and 32 to 38 deg BTDC at 6,000 RPM. With the vacuum line attached, you're probably closer to 10 deg ATDC at idle. Checking the more important 6,000 RPM timing would help show if there is an issue.
icarp 07-21-2019 06:54 PM
check your engine thermostat in the triangle of death, if it not working it will keep the oil in the engine and not release enough oil to the tank . Just an idea
jpnovak 07-21-2019 08:02 PM
Is your engine mounted oil cooler nice and clean? Any crud buildup will greatly reduce the effectiveness of it.
I would also check the tops of your cylinders and heads. You can check it all by pulling heater ducts on front of engine by fan.
The oil cooler will have a gray cover on it. a few bolts and it lifts off. Its much easier done with partial engine drop.
Flat6pac 07-23-2019 04:23 AM
The vacuum line is disconnected at timing.and not needed to set timing.
Setting time at idle should be before TDC, 5 degrees +/-
Vacuum line is a retard for ignition and should ONLY have vacuum at idle
How does it run with vacuum hose plugged?
Bruce
